RS485 For Hypertherms
  • thefabricator03
  • Visitor
  • Visitor
7 years 1 month ago #144668 by thefabricator03
Replied by thefabricator03 on topic RS485 For Hypertherms
Multiple X axies would be cool, I have seen it done on a couple hundred thousand dollar machine for a robotic torch mount and a industrial rotor broach drill for drilling thick sheets.
7 years 1 month ago #144681 by rodw
Replied by rodw on topic RS485 For Hypertherms
Just for the record, there is a supplier I have used here in Brisbane called Shapecut. Their table is 90 metres long... As you can imagine they have more than one gantry.... Some laser, some Plasma and some Laser I think now but they came from heavy cutting with Oxy. They do a remarkably good job with Oxy v's High Def plasma on 32mm plate.
Another steel converter I've seen has a table about 25 metres long. I went and picked up an offcut. I had no idea how big an offcut could be! I laughed as they had some artwork in the office cut from corrugated iron and hardly anyone would know the significance!
Oxy is another tool option then Phill. A lot of tables have flame and plasma combined.
7 years 1 month ago #144682 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
You guys really don't want me to get back to finishing my machine do you? ;)
7 years 1 month ago #144684 by tommylight
Replied by tommylight on topic RS485 For Hypertherms
phillc54 wrote: You guys really don't want me to get back to finishing my machine do you? ;)
Not if we can help it !
Oxy is nice and i have it on 3 or 4 machines, but it does not have much to controll, some valves, a timer for preheat, and slow motion !
So far used it without the THC part, set the z movement to 50mm when jumping form cut to cut and adding a pause before motion enough for the pierce while slowly moving Z down. It worked, never had complaints from clients who use it ( not much ), so all is good.
7 years 1 month ago #144685 by phillc54
I kinda had a look when I first started this project and I think it would be doable. Oxy is all done at one height as well isn't it.
7 years 1 month ago #144689 by tommylight
Yes it is, and it is not height sensitive as plasma.
Adding big buttons for up/down while cutting would be useful.
Basically it is:
-Fire the torch ( acetylene or propane with some oxygen )
-Press run on Linuxcnc
-Wait for the set amount in gcode or panel
-Turn on the relay or the valve for the cutting oxygen
-Engage motion.
Time to create page: 3.449 seconds
