RS485 For Hypertherms
- phillc54
- Thank you received: 2100
- snowgoer540
- Thank you received: 907
Hopefully I didn't break too much...
forum.linuxcnc.org/plasmac/37233-plasmac-updates#163587
So I thought I had my RIP stuff figured out... I still need help wrapping my head around what is going on here. I'll try to explain what I think is going on.
I updated per the directions in section 19. I can go to the -dev folder and see that the scripts were updated in configs/by_machine/plasmac, etc.
I have my launch command to launch out of the -dev folder, using my ini that I set up:
/home/plasma/linuxcnc-dev/scripts/linuxcnc '/home/plasma/linuxcnc/configs/plasma/plasma.ini'
Also I ran the RIP-Environment script again for good measure.
Here's what I dont understand... all of the links point back to the original linuxcnc installation. For example, the target location of plasmac_axis.py is /usr/share/doc/linuxcnc/examples/sample-configs when it should pull from linuxcnc-dev.
I think the answer is to somehow fix all of those links, but i have no idea how to do that easily. I really dont understand why no one else has this problem, or maybe they do and dont realize it. I can only tell it isnt right because I know what you updated, and the updates arent there.
At any rate, I know the easy answer is to go back to a different distro and 2.8, etc. But Mint works so well, I've not been kicked off the wifi once LOL, and it's so nice that it otherwise just works. I really want to learn what's going on and figure this out.
Thanks for the help.
- Thank you received: 4154
. ./linuxcnc-dev/scripts/rip-environmentMy guess is you missed it.
- phillc54
Using this method means you don't need to run rip-environment, the linuxcnc script you pointed to does that for you.I have my launch command to launch out of the -dev folder, using my ini that I set up:
Correct, they still point to your original installation. The way to fix it is to run configurator.py from ~/linuxcnc-dev/configs/by_machine/plasmac/configurator.py then do an upgrade. It won't upgrade if not needed but it should rebuild all the links.Here's what I dont understand... all of the links point back to the original linuxcnc installation. For example, the target location of plasmac_axis.py is /usr/share/doc/linuxcnc/examples/sample-configs when it should pull from linuxcnc-dev.
Won't the LinuxCNC packages from the buildbot run on Mint?At any rate, I know the easy answer is to go back to a different distro and 2.8, etc. But Mint works so well, I've not been kicked off the wifi once LOL, and it's so nice that it otherwise just works. I really want to learn what's going on and figure this out.
- snowgoer540
the rip-environment should set the path variables to point to the run-inplace version. There is a period that is significant...
$ . ~/linuxcnc-dev/scripts/rip-environment
That’s what I ran.. well not the dollar sign. Is that not right?
- snowgoer540
I’m not sure, I think Rob said it wouldn’t. I’m willing to try (I don’t know the repercussions...).
I think I did run the configurator from the old directory so maybe that’s the problem. I’ll give it a go.
- thefabricator03
- Visitor
- phillc54
- phillc54
One of the disadvantages of not using a "linuxcnc" distro.
For a user that just wants to run LinuxCNC I would recommend Stretch + 2.8 from the BuildBot at this moment in time.
You DON'T need to run rip-environment the way you are starting linuxcnc.
- snowgoer540
Got her all fixed up. Who knew running configurator form the -dev folder was the simple answer?! Well, I guess you did...
One more question with regard to updating. Is there a place that shows what version I am on? I had previously remembered a build in the window header, but mine just says "AXIS 2.9.0~pre0 on Plasma". Was thinking it would be nice if there was a definitive way to tell I'm running the latest. Maybe in the help about, or in the Config tab?
Ok, back to testing:
1. The very first time I enabled comms after updating, I couldn't change the gas pressure to anything but 0. Changing modes seems to have fixed it, but it seems like there might be a bug there that needs to be squished.
2. The tooltip for hovering over amps remained the same whether or not comms was enabled. This went away like the issue above when I changed modes, and restarted Plasmac. All the other new tool tips just worked the first time though, so not sure what was up there.
Thanks again for the help. I really am trying to absorb as much of this as I can, if for no other reason than in the hopes that my ability to contribute meaningfully goes up, and I can pay it forward for someone else here.
-Greg
