Center Spot Sheetcam Post
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago - 7 years 1 month ago #144860 by thefabricator03
Replied by thefabricator03 on topic Center Spot Sheetcam Post
Now bigger problems :(
plasma@plasma:~/linuxcnc-dev/src$ linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/plasma/linuxcnc/configs/sws_plasma'
Machine configuration file is 'sws_plasma.ini'
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./sws_plasma.hal
twopass:found ./plasmac.hal
twopass:found ./sws_plasma_connections.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:42:f0
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
note: MAXV max: 500.000 units/sec 30000.000 units/min
note: LJOG max: 500.000 units/sec 30000.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
Warning: Forward kinematics must handle duplicate coordinate letters:yy
Note:
Individual axis homing is not currently supported for
KINEMATICS_IDENTITY with duplicate axis letter <Y>
note: jog_order='XYZ'
note: jog_invert=set([])
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1545, in __call__
return self.func(*args)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 595, in callit
func(*args)
File "/home/plasma/linuxcnc-dev/bin/axis", line 546, in actual_tkRedraw
self.tkRedraw_perspective()
File "/home/plasma/linuxcnc-dev/bin/axis", line 506, in tkRedraw_perspective
self.redraw_perspective()
File "/home/plasma/linuxcnc-dev/lib/python/rs274/glcanon.py", line 352, in inner
return f(self, *args, **kw)
File "/home/plasma/linuxcnc-dev/lib/python/rs274/glcanon.py", line 586, in redraw_perspective
self.redraw()
File "/home/plasma/linuxcnc-dev/bin/axis", line 579, in redraw
return self.redraw_dro()
File "/home/plasma/linuxcnc-dev/bin/axis", line 590, in redraw_dro
limit, homed, posstrs, droposstrs = self.posstrs()
File "/home/plasma/linuxcnc-dev/lib/python/rs274/glcanon.py", line 1515, in posstrs
limit, homed, posstrs, droposstrs = self.dro_format(self.stat,spd,dtg,limit,homed,positions,axisdtg,g5x_offset,g92_offset,tlo_offset)
File "/home/plasma/linuxcnc-dev/lib/python/rs274/glcanon.py", line 1580, in dro_format
if (self.stat.num_extrajoints >0 and (not self.get_show_offsets())):
AttributeError: 'linuxcnc.stat' object has no attribute 'num_extrajoints'
Axis window is 1905 x 1050
HAL: ERROR: pin 'plasmac.thc-active' not found
File "/home/plasma/linuxcnc-dev/bin/axis", line 4127, in <module>
live_plotter.update()
File "/home/plasma/linuxcnc-dev/bin/axis", line 809, in update
o.redraw_dro()
File "/home/plasma/linuxcnc-dev/bin/gladevcp", line 41, in <module>
import gtk
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py", line 40, in <module>
from gtk import _gtk
KeyboardInterrupt
/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py:40: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
ImportError: could not import gio
import gtk
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py", line 69, in <module>
_init()
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py", line 54, in _init
_gtk.init_check()
KeyboardInterrupt
File "/home/plasma/linuxcnc-dev/bin/gladevcp", line 42, in <module>
import gtk.glade
ImportError: cannot import name Widget from gtk
task: 86 cycles, min=0.000006, max=0.010561, avg=0.006624, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/plasma/linuxcnc_debug.txt
and
/home/plasma/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any ideas?
Last edit: 7 years 1 month ago by thefabricator03.
7 years 1 month ago #144863 by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
Did you manage to update or is that from the existing
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144864 by thefabricator03
No I updated.
7 years 1 month ago - 7 years 1 month ago #144865 by dgarrett
Replied by dgarrett on topic Center Spot Sheetcam Post
num_extrajoints was recently added in the master branch
The symptoms show use of an updated file:
lib/python/rs274/glcanon.py which is a python library file
not affected by make, however it requests stat.num_extrajoints
which is provided by emcmodule.cc which must be recompiled
by running make.
so i suspect you need to rebuild:
$ make && sudo make setuid
When updating a branch, its always a good idea to rebuild
or bad things can happen. The 2.8~pre* branch is less volatile
than the master branch.
Last edit: 7 years 1 month ago by dgarrett.
The following user(s) said Thank You: phillc54, thefabricator03
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago - 7 years 1 month ago #144866 by thefabricator03
Thanks dgarrett. that was it.
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago - 7 years 1 month ago #144867 by thefabricator03
Phill,
I tried the drill tool in Sheetcam but the hole marks did not come out in plasmaC gcode.,
When I try to set it up as a plasma tool it tried to cut out the holes rather than spot pecking.
How do you suggest I set it up?
Edit that was the simulation in sheet cam, Ill try running the program and see what happens.
Time to create page: 0.161 seconds
