Center Spot Sheetcam Post
7 years 1 month ago - 7 years 1 month ago #144883 by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
That GCode does 4 centre spots in a straight line that crosses the centre then cuts the inside of a donut then the outside of a donut.
If that is what it is supposed to be then it works in my sim.
Last edit: 7 years 1 month ago by phillc54.
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144890 by thefabricator03
Replied by thefabricator03 on topic Center Spot Sheetcam Post
Changes the spindles to 3 and now it kinda works,
Now I think its a plasma cutter related issue but I am not 100% sure how we will resolve it.
I ran the part out and it only spots two of the four holes. Now PlasmaC is trying to spot the other two holes but the plasma cutter is not reacting quick enough. Maybe we need a delay of some sort,
7 years 1 month ago #144892 by phillc54
One thing I noticed, shouldn't the cut direction be opposite.
The only delay is the Torch On Time but by the look of the holes it is on too long.
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144893 by thefabricator03
I find it interesting that I did not have this issue with my CandCNC setup but I cant quite figure out the difference
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144895 by thefabricator03
phillc54 wrote: One thing I noticed, shouldn't the cut direction be opposite.
I dont know about the cut direction, I have not selected reverse cut in sheetcam, and yeah I had the delay set for longer than needed for the first test.
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144896 by thefabricator03
When PlasmaC is trying to turn on the torch, Its like the torch does not respond. I tried to turn down the motion speed to give the torch more time to respond but that did not help.
Time to create page: 0.064 seconds
