Center Spot Sheetcam Post
7 years 1 month ago #144922 by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
It is odd that it did #1 & #3 but not #2 or #4...
Just change the G4 P3 lines to say G4 P5 and see if that makes a difference. There are five of them.
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144923 by thefabricator03
Replied by thefabricator03 on topic Center Spot Sheetcam Post
No luck Phill,
Same thing happened. I see the torch on light coming on so its trying to tell the plasma to fire, I am not sure why it does not fire though. Its not like is it happening too fast for the plasma to be able to fire.
7 years 1 month ago #144924 by phillc54
OK then try something silly like G4 P10 that should at least eliminate the delay as the problem.
You did reload the GCode file after editing?
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144925 by thefabricator03
OK tried G4 P10, no luck,
And yes I made sure I could see that code in the Axis gcode display.
7 years 1 month ago #144926 by phillc54
Was the behaviour the same, do #1 & #3 miss #2 & #4.
It doesn't make any sense to me.
Does your relay have a light to show it is doing something? (although the pulse is probably a bit quick)
7 years 1 month ago #144927 by rodw
Replied by rodw on topic Center Spot Sheetcam Post
Ok, guys, I worked it out I think!
There is a deliberate delay in the plasma machine to allow gas to flow. After removing the 3 second delay, I got reliable spotting at 220 ms but not at 200 ms.
At one stage when being too fast (maybe 150ms), I could see the air start to flow on the first pierce which missed firing and then the second hole fired becasue the gas was flowing!
So I think Phill is kinda right. You need to wait until the arc fires say > 20 volts or something and then count down the delay then turn off.
At 220 Ms, it was not as fine as I was hoping for but better than waiting for an ArcOK. the 2mm sheet was just pierced with a pin prick. But I need to edit the file becasue it is selecting Stefan's settings which was 6mm steel on my machine and I was cutting 2mm..
Time to create page: 0.187 seconds
