Center Spot Sheetcam Post
7 years 1 month ago #144910 by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
Would it be worth trying a dwell (G4) after each peck then?
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144911 by thefabricator03
Replied by thefabricator03 on topic Center Spot Sheetcam Post
It would be worth a try, If you could modify the g-code file I can test that out.
7 years 1 month ago #144912 by rodw
Replied by rodw on topic Center Spot Sheetcam Post
phillc54 wrote: From what I can gather the 'good' side of the cut is the right hand side so for inside cuts go anti-clockwise and outside go clockwise.
What sort of relay do you use for the torch on.
This varies by machine. On mine it says "Viewed along the direction of travel, the right side of the cut is more square than the left. So this means as Phill said, I go clockwise on outside cuts. I think Sheetcam has a setting to Reverse Direction somewhere.
7 years 1 month ago #144913 by rodw
Stefan, are you using the file Phill uploaded?
7 years 1 month ago #144914 by phillc54
thefabricator03 wrote: It would be worth a try, If you could modify the g-code file I can test that out.
I will modify the code you sent earlier.
When exactly did you hit stop.
  • thefabricator03
  • Topic Author
  • New Member
  • New Member
7 years 1 month ago #144915 by thefabricator03
When it was moving to the next peck. I hit stop and selected the line going to the peck and right clicked the gcode and ran from line.
Time to create page: 0.127 seconds
