GUI for PlasmaC - QtPlasmac
- Thank you received: 4155
13 Feb 2021 14:24 #198712
Replied by rodw on topic GUI for PlasmaC - QtPlasmac
Updated 2.9 RIP this morning and I'm getting this on startup:
This is on my Chromebook. Is there another new module required?
Qtvcp encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version : 2.9.0~pre0
File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1395, in <lambda>
self.consChangePin.value_changed.connect(lambda v:self.consumable_change_changed(v))
File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1154, in consumable_change_changed
self.w[self.ccButton].setEnabled(False)
File "/home/rod/linuxcnc-dev/lib/python/qtvcp/qt_makegui.py", line 341, in __getitem__
return getattr(self, item)
AttributeError: 'VCPWindow' object has no attribute ''
- snowgoer540
- Thank you received: 907
13 Feb 2021 14:27 - 13 Feb 2021 14:28 #198713
by snowgoer540
Phill changed some code for the Change Consumables stuff, and it's (I think accidentally) assuming you have a "change consumables" button.
To get past this in the meantime I just added a change consumables button. For example (formatted for dinosaurs):
This may help you as well: linuxcnc.org/docs/devel/html/plasma/qtpl...t_button-consumables
I'm sure it will get tidied up then.
Replied by snowgoer540 on topic GUI for PlasmaC - QtPlasmac
Qtvcp encountered an error. The following information may be useful in troubleshooting: LinuxCNC Version : 2.9.0~pre0 Traceback (most recent call last): File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1395, in <lambda> self.consChangePin.value_changed.connect(lambda v:self.consumable_change_changed(v)) File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1154, in consumable_change_changed self.w[self.ccButton].setEnabled(False) File "/home/rod/linuxcnc-dev/lib/python/qtvcp/qt_makegui.py", line 341, in __getitem__ return getattr(self, item) AttributeError: 'VCPWindow' object has no attribute ''
BUTTON_6_NAME = CHANGE\TIPS
BUTTON_6_CODE = change-consumables X1 Y1 F150This may help you as well: linuxcnc.org/docs/devel/html/plasma/qtpl...t_button-consumables
Last edit: 13 Feb 2021 14:28 by snowgoer540.
- Mud
- Thank you received: 25
13 Feb 2021 14:35 #198715
by Mud
Replied by Mud on topic GUI for PlasmaC - QtPlasmac
I've been watching this thread with interest but sadly been too short on time to play. I'm currently running Linux 2.8 on Mint 19.2 and I must be 3+ months behind on PlasmaC - I've ordered a new SSD to join in without worry of scuppering myself and running out of playtime. What's the current recommendation to get up and running with minimal fuss?
13 Feb 2021 14:57 #198725
Thanks that fixed it. I added that to the sim's ini file (or the .inc file.) and it works.
Mud, youi just need to install V 2.9 and its deployed for you. Then read the docs
BUTTON_6_NAME = CHANGE\TIPS BUTTON_6_CODE = change-consumables X1 Y1 F150
/linuxcnc-dev/configs/by_machine/qtplasmacMud, youi just need to install V 2.9 and its deployed for you. Then read the docs
The following user(s) said Thank You: Mud
13 Feb 2021 15:01 #198728
What I did when I was way out of date was to build a config with pncconf with no config and cut and paste the configured data until I had a working config without plasma, Than ran the configurator.
I think I'll need to do that again with qt plasmac soon. I have it running with a 7i76e in my office but no motion hardware.
- Thank you received: 7505
13 Feb 2021 15:41 #198734
Replied by tommylight on topic GUI for PlasmaC - QtPlasmac
If you mean installing and everything else:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
forum.linuxcnc.org/qtvcp/38414-installing-qtvcp
will get you up and running in under an hour including the downloads.
13 Feb 2021 15:45 #198735
Shhh.... do not tell Phill, but i did make QtPlasmaC work on the big machine in about 5 minutes, then after a while tried to do that on my main PC and could not make it work for over an hour so i gave up ! I will have to copy it from there and use it everywhere and save it as if it was dinosaurs DNA ! No, not the Australian "dinosaur" that you guys keep mentioning, i still do no know what that is about or i forgot or ...I think I'll need to do that again with qt plasmac soon.
- phillc54
- Thank you received: 2100
13 Feb 2021 16:41 #198742
by phillc54
I just pushed the fix for this.
Replied by phillc54 on topic GUI for PlasmaC - QtPlasmac
13 Feb 2021 17:12 #198746
I just pushed the fix for this.[/quote]
Thanks, I was thinking afterwards that there needs to be some error checking for this so that a user changing a button config does not break the system.
And don't forget we need a few buttons left for the user to use!
- phillc54
13 Feb 2021 17:18 #198749
by phillc54
There is and this was a bug...
Thanks, I was thinking afterwards that there needs to be some error checking for this so that a user changing a button config does not break the system.I just pushed the fix for this.
The eight user buttons can be any valid user button, none are set in stone...And don't forget we need a few buttons left for the user to use!
Time to create page: 0.323 seconds
