- Thank you received: 4153
If it does as advertised then YES.cmorley wrote: This does what you guys need though yes?
Reverse run is used manually for error recovery so for plasma users it would not be a major concern if velocity was reported wrongly during reverse runDo you use reverse run - I haven't tested it with reverse run.
cmorley wrote: It's not in master yet Rod ..that's a testing branch.
Chris
