New pin motion.base-feedrate in master branch
- Thank you received: 2181
28 Mar 2020 23:57 #161875
Replied by cmorley on topic New pin motion.base-feedrate in master branch
There is a discussion on the maillist - it seems we have a couple single points of failure - currently only one? two? people can do some requirements.
The ball is ...rocking
Chris
Chris
- phillc54
- Thank you received: 2100
28 Mar 2020 23:59 #161877
by phillc54
Replied by phillc54 on topic New pin motion.base-feedrate in master branch
So it just needs a nudge to make it roll...
- Thank you received: 4149
29 Mar 2020 00:11 #161882
Andy, I'm glad you have no idea The issue with State tags when I've looked at it in the past is that there is no mechanism to extract the new tags data in Hal.
And today proves exactly that!
I have run this up on my plasma table and can confirm nothing has broken. But also no pins show the tags.
I think what is needed is a component that publishes the tags so they can be read in Hal.
Any ideas how a component can access the tags structure? If we could get that far, this would be useful and replace Chris's feedrate pin.
Chris, I think Phill's Reverse run could be included in V 2.8. It has more than enough testing over the last 12 months to prove it does not break anything. It would be great if you two guys could make that happen.
Replied by rodw on topic New pin motion.base-feedrate in master branch
I actually have no idea.
I _think_ that it mainly keeps the "status" stuff up to date.
I think ideally Chris' extra HAL pin would be added too. And maybe a few more.
Eventually I'll just do what I think is best at the moment and if people don;t like it they can come take this lead
- phillc54
29 Mar 2020 00:39 #161891
by phillc54
I have seen references to StateTags for a few years now and it would be nice to know exactly what State Tags does and what issues it fixes.
I have read here (or maybe seen on the list) that Tormach uses State Tags, does anyone know how they use it and what benefits are gained.
29 Mar 2020 01:04 - 29 Mar 2020 01:05 #161900
I think the intent is to publish the gcode parameters that are thrown away after they are read and tokenised to motion.
My understanding is that it adds an additional structure to emcmot_command_t around line 209 in
github.com/LinuxCNC/linuxcnc/blob/andypu.../emc/motion/motion.h
And that structure is defined in
github.com/LinuxCNC/linuxcnc/blob/andypu...c/motion/state_tag.h
So in motion.c github.com/LinuxCNC/linuxcnc/blob/andypu.../emc/motion/motion.c
It should be able to add new pins for the tags as they are known in this code.
I don't know the python stuff at all, but I assumed that data is available in linuxcnc.org/docs/2.6/html/common/python-interface.html but I may be way off.
So now with Andy's foundation work, maybe Chris can advise how to publish those pins.
Last edit: 29 Mar 2020 01:05 by rodw.
- phillc54
29 Mar 2020 05:41 #161913
by phillc54
I am still none the wiser, I had a bit of a grep but there is not much in the way of documentation.
I also noted several runtest failures that I guess will require investigation (I had no failure in 2.8 or master)
Failed:
/home/phill/linuxcnc-dev/tests/abort/g64
/home/phill/linuxcnc-dev/tests/interp/m98m99/01-basics
/home/phill/linuxcnc-dev/tests/interp/m98m99/05-M98-loops
/home/phill/linuxcnc-dev/tests/interp/m98m99/09-disable-fanuc-subs
/home/phill/linuxcnc-dev/tests/motion-logger/startup-gcode-abort
/home/phill/linuxcnc-dev/tests/startup-statePlease Log in or Create an account to join the conversation.
29 Mar 2020 06:23 #161915
Phill, this issue may help but really I am in the dark a bit too.
github.com/LinuxCNC/linuxcnc/issues/440
This was raised by PCW when Islander261 finally worked out that motion.requested.vel was not docuemented correctly.
I spent a number of hours exploring the code in the /src/emc folder and the relationships between cannon, task and motion to see if I could do what Cam has achieved but gave up.
Basically, each module is firewalled from each other and use interprocess messages to communicate. A global status structure is maintained. From memory, this is EMCMOTSTATUS and it is based on the structure I linked to.
State tags added an extra structure to this global structure and it is updated by cannon before motion commands are tokenised and passed to the trajectory planner.
But I think the missing link is publishing this additional data to hal so it can be used. It will be interesting to hear feedback from Cam and Andy.
29 Mar 2020 07:05 #161917
I'd really appreciate an explanation of how this works and why so this thread would be a good spot to do this.
So the state tags are updated in
github.com/LinuxCNC/linuxcnc/blob/andypu...4ngc/interp_write.cc
in procedureon line 210
So at this point I'm assuming the rs274 code has been parsed and the status (and state) is written to the other rmodules
in procedure
int Interp::write_state_tagSo at this point I'm assuming the rs274 code has been parsed and the status (and state) is written to the other rmodules
29 Mar 2020 09:08 #161924
block is one line of gcode
settings is the current interpreter settings
Statetag is new but obviously must be the current gcode state
Chris
Interp::write_state_tag(block_pointer block,
setup_pointer settings,
StateTag &state)settings is the current interpreter settings
Chris
29 Mar 2020 10:59 #161948
Yes the StateTag structure is added to the emcmot_hal_data structure
So Chris if you have a look at motion.c Line 335, there is a procedure called init_hal_io that defines the motion pins. I'm sure you know this
Something like this should find the feed rateSee: github.com/LinuxCNC/linuxcnc/blob/andypu...c/motion/state_tag.h
And finally, a definition of what State tags does in that file
So let me know when you have a feed rate pin using State tags
block is one line of gcodeInterp::write_state_tag(block_pointer block, setup_pointer settings, StateTag &state)
Chris
emcmot_hal_data->tag->fields[GM_FIELD_FLOAT_FEED] // array index [1]And finally, a definition of what State tags does in that file
* Tag structure that is added to a motion segment so that motion has a copy of
* the relevant interp state.
* Previously, this information was stored only in the interpreter, and as
* vectors of g codes, m codes, and settings. Considering that the write_XXX
* and gen_XXX functions had to jump through hoops to translate from a settings
* struct, the extra packing here isn't much more complex to deal with, and
* will cost much less space when copying back and forth.
*/So let me know when you have a feed rate pin using State tags
Time to create page: 0.767 seconds
