- Thank you received: 2181
cmorley wrote: That HAL pin must be requested-vel?
Does your HAL pin suffer from the not-synched-to-motion problem?
Maybe it's not much of a problem usually.. only comes up if you change the feedrate in the program - status shows the last feed code in the program as soon as the interpreter reads that far ahead.
Cornerlock only from memory.rodw wrote: So Phill, do we only need this for cornerlock? Thats my understanding. I just wondered if you used it for anything else.
I think you need Arc OK plus THC ActiveI had a bit of a play swappiing some pins around but did not see the cornerlock ever cut in even without me changing anything. But it should have. Does it need to be cutting for it to kick in? I was only dry cutting.
I must have left that in after i ripped out the remap junk, I am sure it is not used.Also, what was the purpose of the pin plasmac.requested_velocity? I could not see it was used.
