New pin motion.base-feedrate in master branch
24 Mar 2020 23:15 #161376 by phillc54
Replied by phillc54 on topic New pin motion.base-feedrate in master branch
As I said, I need to think a lot more about it. It works OK as is so there is no need to rush.
25 Mar 2020 08:14 #161400 by fixer
Cmorley, thank you!
This is great addition, even for milling and turning. It should be possible to show real feed value on user interface now.
It does, however only work with G94. With G93 and G95 it reports 0.0.
rtapi_print( "SET_Fcode status: %f\n", emcmotCommand->fcode) executes only when G94 is called. Do you think you could fix for G95 to show correctly?
25 Mar 2020 08:16 #161401 by cmorley
Replied by cmorley on topic New pin motion.base-feedrate in master branch
I'll look into it.
Thanks for testing
Chris
25 Mar 2020 08:25 - 25 Mar 2020 08:25 #161403 by fixer
Already found it, here in emccanon.cc:
void SET_FEED_RATE(double rate)
    if(feed_mode) {
	START_SPEED_FEED_SYNCH(rate, 1);
	currentLinearFeedRate = rate;
    send_code_status_msg(rate);  //G95
    } else {
	/* convert from /min to /sec */
	rate /= 60.0;
	/* convert to traj units (mm & deg) if needed */
	double newLinearFeedRate = FROM_PROG_LEN(rate),
	       newAngularFeedRate = FROM_PROG_ANG(rate);
	if(newLinearFeedRate != currentLinearFeedRate
		|| newAngularFeedRate != currentAngularFeedRate)
	    flush_segments();
	currentLinearFeedRate = newLinearFeedRate;
	currentAngularFeedRate = newAngularFeedRate;
	send_code_status_msg(rate*60.0);  //G94
Last edit: 25 Mar 2020 08:25 by fixer.
25 Mar 2020 08:27 #161404 by cmorley
Thanks I'll fix that right away :)
Chris
25 Mar 2020 08:51 #161405 by cmorley
I ended up with:
	// send a code status NML message with the F word setting
    if(canon.feed_mode) {
	START_SPEED_FEED_SYNCH(canon.spindle_num, rate, 1);
	canon.linearFeedRate = rate;
    } else {
	rate /= 60.0;
	if(newLinearFeedRate != canon.linearFeedRate
		|| newAngularFeedRate != canon.angularFeedRate)
	    flush_segments();
	canon.linearFeedRate = newLinearFeedRate;
	canon.angularFeedRate = newAngularFeedRate;
Which seemed to work the same.
Pushed to the testing branch.
Thanks for the fast code review!
Chris
25 Mar 2020 10:34 #161413 by fixer
Great, thank you! I applied changes to 2.7 and it also works there.
25 Mar 2020 16:25 #161470 by fixer
Chris,
Could you add feed per revolution value to this pin when in spindle synchronized motion (G33, G76)?
26 Mar 2020 07:59 - 26 Mar 2020 07:59 #161543 by cmorley
Pushed an enhancement for this - please let me know if it's working for you
Chris
Last edit: 26 Mar 2020 07:59 by cmorley.
26 Mar 2020 15:16 #161573 by fixer
Works for me, exactly what I had in mind!
Thank you!
Time to create page: 1.995 seconds
