New pin motion.base-feedrate in master branch
6 years 7 months ago #161404 by cmorley
Thanks I'll fix that right away :)
Chris
6 years 7 months ago #161405 by cmorley
I ended up with:
void SET_FEED_RATE(double rate) { // send a code status NML message with the F word setting send_code_status_msg(rate); if(canon.feed_mode) { START_SPEED_FEED_SYNCH(canon.spindle_num, rate, 1); canon.linearFeedRate = rate; } else { /* convert from /min to /sec */ rate /= 60.0; /* convert to traj units (mm & deg) if needed */ double newLinearFeedRate = FROM_PROG_LEN(rate), newAngularFeedRate = FROM_PROG_ANG(rate); if(newLinearFeedRate != canon.linearFeedRate || newAngularFeedRate != canon.angularFeedRate) flush_segments(); canon.linearFeedRate = newLinearFeedRate; canon.angularFeedRate = newAngularFeedRate; } }
Which seemed to work the same.
Pushed to the testing branch.
Thanks for the fast code review!
Chris
6 years 7 months ago #161413 by fixer
Great, thank you! I applied changes to 2.7 and it also works there.
6 years 7 months ago #161470 by fixer
Chris,
Could you add feed per revolution value to this pin when in spindle synchronized motion (G33, G76)?
6 years 7 months ago - 6 years 7 months ago #161543 by cmorley
Pushed an enhancement for this - please let me know if it's working for you
Chris
Last edit: 6 years 7 months ago by cmorley.
6 years 7 months ago #161573 by fixer
Works for me, exactly what I had in mind!
Thank you!
Time to create page: 0.132 seconds
