- Thank you received: 2100
IMHO it is supposed to reflect what was in the GCode so it should be units/minute.rodw wrote: The only consideration is that it shows exactly what the F command is. (in my case 1425 mm/min)
Should it show feedrate per second to be consistent with all the other velocities? (eg. 1425/60 = 23.75)
Phill doesn't even think about it until it is in master. :lol:How does Phill use it in Plasmac?
thefabricator03 wrote: Rod,
Can you explain exactly what this means for the uneducated? Is it just a cleaner way to do the same thing Phil has done?
Also what exactly is state tags again?
No, we did use remap but as you said it is a pain so we gave it away.cmorley wrote: I believe you guys use remap for this at the moment? Using this would lower the bar for users - Remap is a pain
cmorley wrote: That HAL pin must be requested-vel?
Does your HAL pin suffer from the not-synched-to-motion problem?
Maybe it's not much of a problem usually.. only comes up if you change the feedrate in the program - status shows the last feed code in the program as soon as the interpreter reads that far ahead.
