PlasmaC Fiber laser 1Kw head height control + auto focuas
11 Apr 2020 01:13 #163552 by taloot
Taloot, Do you have a way I can get in contact with you. I would like to find out more information about your lasers.
my s k y p e
taloot abdullah
11 Apr 2020 01:15 #163553 by taloot
i have problem ,, the signal come from THCAD... isnt stable,, its changing with in limit fluctuation ... do i have to use lowpass filter?
11 Apr 2020 03:23 - 11 Apr 2020 03:26 #163565 by PCW
The THCAD output should be about 10 bit resolution if read every 1 ms servo thread period
you can improve the resolution (at the expense of bandwidth) by low pass filtering
You can verify noise level by using a 9V battery
If you dont need HV protection and high isolation, a 7I87 is probably a better choice
as you can get 12 bit resolution independent of servo thread rate
Last edit: 11 Apr 2020 03:26 by PCW.
11 Apr 2020 03:39 #163567 by taloot
how can i stabilize the reading from thcad
i have no luck to link the lowpass filter as most examples in the forum is, for spindle
11 Apr 2020 03:44 #163568 by phillc54
If you are using the PlasmaC component it has a built in low pass.
github.com/LinuxCNC/linuxcnc/blob/master...smac_connections.hal
11 Apr 2020 06:17 #163578 by taloot
im experimenting outside plasmac.
i have about 1% fluctuation... is that normal?
11 Apr 2020 09:55 #163593 by phillc54
Have you tried with a battery as the input source.
11 Apr 2020 13:07 - 11 Apr 2020 13:08 #163605 by taloot
i have 0-10v signal generator
same as this.,
www.google.com/search?q=0-10v+generator&...imgrc=AkuSyKsLNCEOqM
after applying lowpass filter is 0.01% fluctuation
Last edit: 11 Apr 2020 13:08 by taloot.
11 Apr 2020 13:11 #163606 by taloot
there is no much noise from the system,, 10 bit is good for me
but how can the low pass filtering effect the resolution
