PlasmaC Fiber laser 1Kw head height control + auto focuas
- thefabricator03
- Thank you received: 531
30 Mar 2020 20:13 - 30 Mar 2020 20:14 #162137
by thefabricator03
There are a few local cutting shops in my area that do just that. Up to 10mm with laser and over 10mm with plasma. But they have spent upwards of $750,000 on their machinery.
Just curious, what are your intentions with PlasmaC?
Replied by thefabricator03 on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
3kw can cant very fast on thin metal,,, but i suggest for high thinknness to buy fine plasma also chinese with gas and protected torch similar to xpr
www.jscut.cn/product/205_374
also the have cheaper model cost 2500 for 200a plasma ,,, its very good and clean i have sample cut
i use plasma for thick plate and for 10mm and less laser .. both machines less cost than hypertherm xpr
Last edit: 30 Mar 2020 20:14 by thefabricator03.
- Thank you received: 5927
30 Mar 2020 21:45 #162153
Replied by tommylight on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
There was a member here a while back that did a retrofit on a new machine of this type, and he confirmed what i was able to gather on the net that the software that comes with those machines is very bad, to the point that hitting esc or e-stop will leave the laser on at full tilt ! And they use windoze through USB, so ........Just curious, what are your intentions with PlasmaC?
The following user(s) said Thank You: taloot, thefabricator03
- thefabricator03
30 Mar 2020 22:23 #162166
by thefabricator03
Lol, lasers and not being able to turn them off defiantly do not mix!!. I wonder if in the future we will get LaserC. I have started working on RobotC in my spare time. Then all that will be left will be WaterJetC and we will be sorted!
30 Mar 2020 22:29 #162170
Have not bumped into that, yet.
Hmm and that would be ????I wonder if in the future we will get LaserC. I have started working on RobotC in my spare time. Then all that will be left will be WaterJetC and we will be sorted!
30 Mar 2020 22:29 #162171
by phillc54
But they would need to be PlaserC, ProbotC and PwaterjetC so they have my initials...
Replied by phillc54 on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
The following user(s) said Thank You: tommylight, thefabricator03
30 Mar 2020 22:34 #162172
Yes yes !But they would need to be PlaserC, ProbotC and PwaterjetC so they have my initials...
- thefabricator03
30 Mar 2020 23:02 #162180
by thefabricator03
I always knew PlasmaC has another meaning apart from Plasma Component
31 Mar 2020 00:25 #162188
by phillc54
Yes, an ulterior motive at play...
I always knew PlasmaC has another meaning apart from Plasma ComponentBut they would need to be PlaserC, ProbotC and PwaterjetC so they have my initials...
31 Mar 2020 00:42 #162189
Replied by rodw on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
I recall a time when it had no name.... Just another plasma component
The following user(s) said Thank You: phillc54, thefabricator03
31 Mar 2020 08:27 #162209
by taloot
Replied by taloot on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
yes + spending 1500$ on that buggy software
Time to create page: 0.266 seconds
