PlasmaC Fiber laser 1Kw head height control + auto focuas
22 May 2020 16:16 - 22 May 2020 16:28 #168586
by taloot
sure i know this,, JPT is well known in marking laser also the provide overseas support,,, but i buy it coz its 40% less weight and cheaper
also the core size for fiber can be customized ( bigger fiber core better for cutting in thick material,,, but not as good as small core for highly reflective material
btw there is another laser brands and cheap but no history no support they have
reci now making fiber laser too, but i cant trust it,,,
i will add the scale calculation and offset in GUI,,
Replied by taloot on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
My experience with CO2 laser tube from china is bad, i brought 3 time 100W tube, quality control is very low, after few moths of use they had leakage. Now i buy in Japan, expensive but no problem at the end become cheap.
Be careful dude, the cheap maybe give to you headache
Last edit: 22 May 2020 16:28 by taloot.
29 May 2020 10:57 #169302
by taloot
i make additional fix. and i added IIR filtering.
20 Jul 2020 13:12 - 20 Jul 2020 13:19 #175253
by taloot
1st test ss 0.9mm speed was 16m/min
after tweak gas and focus i reached 25m/min
alot of tweaks to LCNC i think it need completely new GUI..
on laser control there if power and frequency
power can be 0-10
freq 50KHZ same as modulation frequency lower freq @ pircering and higher @ cutting
power can be 0-10
Last edit: 20 Jul 2020 13:19 by taloot.
- Thank you received: 5926
20 Jul 2020 14:33 #175258
Replied by tommylight on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
Nice.
The following user(s) said Thank You: taloot
- thefabricator03
- Thank you received: 531
21 Jul 2020 00:09 #175284
by thefabricator03
Replied by thefabricator03 on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
Very nice work. I will buy a laser source in a couple of years and build my own like yours.
30 Jul 2020 15:46 - 30 Jul 2020 15:57 #176536
by taloot
the main diffrance between laser and plasma is as follow
laser have PWM on 24v for modulating of the laser
0-10 v to set the power
enable / disable for shutter
gas control also another story
there is pricing gas pressure and cutting gas pressure
this is connect to 0-10v --- to SMC propotional regulator this is for o2 only
for n2 only on and off valve and same to air..
i make qtpyvcp using serial comm to laser source source,, but u still need PWM pin
capacitance sensor i make already..
if anyone have an idea about any one of those and how to make it the correct way let me know
so there is pircing and cutting each one need the follow
freq 0-20khz depent on ur laser
power 10 -100
gas type N2 O2 Air
gas pressure in psi
foucs setting <--- this is only important when u cut thick metal
i have chinese cutting system... but its very weak compare to linuxcnc,., no way to compare
power 10 -100
gas type N2 O2 Air
gas pressure in psi
Last edit: 30 Jul 2020 15:57 by taloot.
30 Jul 2020 16:58 #176541
PWM is quite easy to do with discrete elements, 2 transistors and some resistors.
Or there are cheap modules that do that:
www.google.com/search?source=hp&ei=W_siX...vzBGMQ4dUDCAY&uact=5
www.amazon.co.uk/Voltage-Converter-2KHZ-...erface/dp/B07WJHF2N8
30 Jul 2020 17:06 - 30 Jul 2020 17:11 #176543
by taloot
7i7e i think it should work without the need for the converter
Last edit: 30 Jul 2020 17:11 by taloot.
30 Jul 2020 17:10 #176544
by taloot
i have this for this application
store.mesanet.com/index.php?route=produc...69_63&product_id=290PWM is quite easy to do with discrete elements, 2 transistors and some resistors.
30 Jul 2020 22:19 #176569
by Becksvill
Replied by Becksvill on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
hey taloot.
I am also interested in making a laser cutter.
did you end up getting plasmac going ok for laser cutters.
6k sounds like a pretty good price for a laser cutting head. and the mechanical machine would be easy as to make. it is just the laser beam controlling that is hard I think. and I would be very interested in seeing what you have gotten up to with that. in a few years I think I might try build one of these
Andrew
Andrew
Time to create page: 0.200 seconds
