PlasmaC Fiber laser 1Kw head height control + auto focuas
31 Mar 2020 08:29 #162210
by taloot
Replied by taloot on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
yes 750k you are right,,, but u can build it less than 10k if we have the right software
31 Mar 2020 08:33 #162211
by taloot
you can fix it easily,,, i just need to cancel the probing routine + i will make device send the capacitance to THCAD
or i make device send the capacitance to the encoder pin inside mesa card,,,
this is the fastest way i guess
in dedicated for this,,,
There was a member here a while back that did a retrofit on a new machine of this type, and he confirmed what i was able to gather on the net that the software that comes with those machines is very bad, to the point that hitting esc or e-stop will leave the laser on at full tilt ! And they use windoze through USB, so ........Just curious, what are your intentions with PlasmaC?
Lol, lasers and not being able to turn them off defiantly do not mix!!. I wonder if in the future we will get LaserC. I have started working on RobotC in my spare time. Then all that will be left will be WaterJetC and we will be sorted!
But they would need to be PlaserC, ProbotC and PwaterjetC so they have my initials...
31 Mar 2020 08:37 #162212
by taloot
you solved big issues for plasma,,,
you make the work flow more smooth for plasma operator ,, you are very professional in framing this
Yes, an ulterior motive at play...
I always knew PlasmaC has another meaning apart from Plasma ComponentBut they would need to be PlaserC, ProbotC and PwaterjetC so they have my initials...
- thefabricator03
- Thank you received: 531
31 Mar 2020 08:43 #162213
by thefabricator03
Replied by thefabricator03 on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
Do you have any pictures of your laser machine? The more pictures the better!
- thefabricator03
31 Mar 2020 08:47 #162214
by thefabricator03
I will build one soon. Well relativity soon. I have many many projects before I can get to a CNC laser. Although having one would be very handy for some of my up coming projects.
With another child on the way it makes it difficult to fund my hobbies. I need to start making more money lol.
- thefabricator03
31 Mar 2020 08:49 #162215
by thefabricator03
In keeping with the LinuxCNC open source spirit. Could you please post your code changes when you are finished. I am sure many more people could benefit from your work.
31 Mar 2020 09:24 #162217
by taloot
laser it pay it self,,, u can do very good products u cant do with plasma,, ( also dont forget to buy welding gun,,) cut and weld laser in ur home,,
The following user(s) said Thank You: Sadmeatball
31 Mar 2020 09:27 #162218
by taloot
Sure thing,,,
without linuxcnc,, world will be different (very high performance with extremely low cost) thanks mesa
the good with plasmac that u can controll everything,, under simple clean UI ,,,
Sure thing,,,
- thefabricator03
31 Mar 2020 09:31 - 01 Apr 2020 11:27 #162219
by thefabricator03
Lol I will not forget to buy a welding gun,
A humble brag but this is what a robotic inverter welder looks like.
And this is the latest welding gun I have brought,
After around 10 years of welding everyday I decided to let machines do my welding.(Although I do miss it sometimes)
Last edit: 01 Apr 2020 11:27 by thefabricator03.
31 Mar 2020 09:39 #162220
by taloot
then i wont use the RS485 capacitace,,, i will use another head,, that comes without it,,, and i will use stm32 to measure the capacitance and send it to mesa board ..
i will post some videos
Time to create page: 0.444 seconds
