Hypersensing questions
6 years 6 months ago #165168 by PCW
Replied by PCW on topic Hypersensing questions
If 25V full scale and 1 mA full scale sense current are a good
choice I could make a THCAD version with the right resistors so
no added parts are needed...
6 years 6 months ago #165170 by rodw
Replied by rodw on topic Hypersensing questions
PCW wrote: If 25V full scale and 1 mA full scale sense current are a good
I think we should get feedback from Snowgoer as well. I think also that using a moving average will help smooth the signal and remove some of the noise. Here is a plot of average volts with N=10. I found N=5 was still a bit twitchy.
Blue line is the average, red line is actual volts... I've also added some pins so I can turn the relay on when motion.motion-type > 0
That lets the relay turn on when an axis moves so it can start averaging volts before a probe event.
I'm still not done playing here though.
Peter is smoothing the signal wise do you think?
6 years 6 months ago #165172 by phillc54
Replied by phillc54 on topic Hypersensing questions
I don't think smoothing the signal is wise if it causes too much delay thus increasing overrun.
You could slow your probing down which only works after probe height is reached.
The other issue is if your material is bucked enough to go above probe height you will increase the risk of crashing.
6 years 6 months ago #165175 by snowgoer540
Replied by snowgoer540 on topic Hypersensing questions
My resistors are delayed :angry: Mouser was supposed to ship yesterday with overnight to make up for the delay.. then today... which didn’t happen. Really hoping I get them by Friday so I can do some testing on the weekend. But it is what it is in the world today.
I did get a nice solid state relay to control the power supply though so at least I’ll get that wired in tomorrow maybe.
6 years 6 months ago - 6 years 6 months ago #165176 by snowgoer540
phillc54 wrote: I don't think smoothing the signal is wise if it causes too much delay thus increasing overrun.
I’m not sure smoothing it out is the answer yet either. I plan to test with the original ohmic comp file, because other than the wet torch issue, everything seemed to be working ... but I’m rather new to ohmic sensing so maybe I don’t know what I don’t know yet ..
Last edit: 6 years 6 months ago by snowgoer540.
6 years 6 months ago #165179 by rodw
These are not valid concerns. We only use the smoothed signal at the end of probing so the torch is moving away from the material. There is no possibility of a crash. Also, we no longer use the low threshold so the sensitivity of the new method is actually increased.
I think you said it is then travelling at 0.001mm per servo cycle. Absolute worst case is the surface is out 0.01mm but in reality, the voltage is dropping very quickly from the full scale reading so I would expect any delay is a lot less than 10 servo cycles due to the added weight of the last couple of readings. What we don't want is the probe signal to oscillate on and off because of voltage spikes when contact breaks.
What I'd like to do is to come up with a method that self learns and auto calibrates continuously so the concept of a threshold is rendered obsolete. As it is, we have done away with the low threshold, we just need to do away with the high threshold now.
Time to create page: 1.165 seconds
