- Thank you received: 4153
Hypersensing questions
6 years 6 months ago #165342
Replied by rodw on topic Hypersensing questions
Looking good. Can you bring the threshold down a bit so you don't get the probe signal going off in the middle of the run?
It looks like your threshold is right at your full scale voltage. Maybe 1 volt to be safe but even 0.5 volts. would be nice.
The signal is nice and smooth now anyway
- Uthayne
- Thank you received: 49
6 years 6 months ago #165343
by Uthayne
Replied by Uthayne on topic Hypersensing questions
Yeah it would probably benefit from some tuning. My threshold is actually at 23v. If you're looking at the pictures, the cut section is later and was cropped out.
The signal is much cleaner, great work on the comp!
- Thank you received: 7491
6 years 6 months ago #165366
Replied by tommylight on topic Hypersensing questions
@Rod,
You are relentless ! Good work.
6 years 6 months ago #165369
If you build it, they will come !
tommylight wrote: @Rod,
6 years 6 months ago #165372
6 years 6 months ago #165375
Thats great to know. I'm going to leave it like this for now until we get some more feedback (snowgoer540 where are you?)
I really want to focus on the void/kerfcrossing stuff. Hopefully I will have it nailed over the weekend.. Its one of those things where one cut generates enough data to keep me busy for hours studying code and I think I found the error in my algorithm...
Uthayne wrote: The signal is much cleaner, great work on the comp!
Time to create page: 0.571 seconds
