Hypersensing questions
6 years 3 months ago #176499 by tommylight
Replied by tommylight on topic Hypersensing questions
Some very valid answers here, so as icing to a cake, Nasa uses metric ( lost spaceships Rod mentioned ), the US military uses metric ( lost solders maybe?? ).
6 years 3 months ago #176503 by rodw
Replied by rodw on topic Hypersensing questions
tommylight wrote: Some very valid answers here, so as icing to a cake, Nasa uses metric ( lost spaceships Rod mentioned ), the US military uses metric ( lost solders maybe?? ).
The yanks always loose soldiers even on joint exercises with the Anzacs!
  • snowgoer540
  • Moderator
  • Moderator
6 years 2 months ago #178317 by snowgoer540
Replied by snowgoer540 on topic Hypersensing questions
rodw wrote: Attached is a revised component.ohmic3.comp.. You will need to edit your halfile from ohmic2 to ohmic3.
I had some issues where this was a bit forgetful and forgot to turn the probe off when retracting so this does a bit more checking. Seems OK now after cutting a full sheet.
@Rod
So I helped a friend update to this today. He updated his <machine>_connections.hal file to change it to ohmic3. He says that ohmic probing doesn't work at all now. I am not sure why it wouldn't, so I had him switch back to ohmic2, which does work.
Any thoughts? At first, I thought that maybe his thresholds needed tweaking, but why would ohmic2 work and not ohmic3?
Another question I had, looking at the comp file, all of the pins get assigned values. I assume this gets overridden because Halscope did show my values, but I was wondering why they get hard set in here:
// Example Calibration Data: 0v = 122.9 kHz, 10v = 925.7 Khz should be entered as 122900 and 925700 pin in float thcad_0_volt_freq "0 volt calibration data for THCAD card in Hz"; pin in float thcad_max_volt_freq "Full scale calibration data for THCAD Card in Hz"; pin in float thcad_divide = 32 "THCAD Divider set by links on THCAD board (1,32,64 or 128"; pin in float thcad_fullscale = 5 "THCAD Fullscale (5, 10 or 300)"; pin in float velocity_in "The velocity returned from the THCAD and read by the Mesa encoder input"; pin in float volt_divider = 4.9 "The divide ratio (default 1:1)"; pin in float ohmic_threshold = 18 "The threshold volts above which Ohmic sensing is set to be true"; pin in float ohmic_low = 5 "The threshold volts below which Ohmic sensing is set to be false"; pin out bit arc_on "True if full scale (eg arc is on)"; pin out float thcad_volts "Measured thcad voltage"; pin out float ohmic_volts "Calculated Ohmic voltage"; pin out bit ohmic_on "Threshold plasma torch voltage"; pin in bit is_probing "True if probing"; pin in s32 motion_type_in "Connect motion.motion-type here"; pin out bit power_on "Turn relay on with this pin"; pin in s32 mode = 0 "0 = use low threshold, 1 = use trend"; pin in s32 num_readings = 5 "number of servo cycles to stay on trend"; pin out float dbg_avgv "average arc volts"; function _; license "GPL";
6 years 2 months ago #178332 by rodw
The values shown are defaults which will apply if no value is set to that pin in hal but you can set them to anything you wish using setp or a net command. So they are not hard coded. I tend to do this to set sensible defaults if something is missed.
I don't think much has changed between versions. I'd have to see the hal file connections. I know Phill is now using motion.motion-type in plasmac now though.
I think using a MPG to make and break the ohmic connection with a dry and wet torch and monitoring the voltage on the 24 v isolated circuit in the ohmic3 component helps to set a threshold. OR just probe fr a hole and use halscope.
  • snowgoer540
  • Moderator
  • Moderator
6 years 2 months ago #178336 by snowgoer540
:blush: whoops, I meant to attach that.
It's attached, but like I said, it doesn't make sense because ohmic2 works and ohmic3 doesn't. You'd think they both wouldn't work if it was a problem with the hal file.
Hmm.
At any rate, he went to ohmic3 because he was having the problem you described with it not turning off the probing at the correct times, etc.
6 years 2 months ago #178342 by rodw
I've got a mess in my workshop pending delivery of a press brake tomorrow so I can't get to the plasma to check for a couple of days.
The main thing would be the threshold, is there power to the circuit (light on on power supply) and that you can see the voltage in halshow changing from 0-24 or so volts
Time to create page: 0.244 seconds
