- Thank you received: 338
Hypersensing questions
- bevins
5 years 7 months ago #202729
by bevins
OK noted. Where do I put this comp file and how to reference it?
Replied by bevins on topic Hypersensing questions
rodw wrote: By my calculations, a 147k resistor will give a 24.7 volt full scale which would work well instead of 390k
- Thank you received: 4153
5 years 7 months ago #202731
Replied by rodw on topic Hypersensing questions
(sudo) halcompile --install ohmic3.comp
Then include the provided hal file in my spoiler which unlinks anything required except motion-status as mentioned
sudo is not required for a rip build
- bevins
5 years 7 months ago #202734
by bevins
OK but is that file going to compile with all those .br in there? and uncommented comments?
rodw wrote: (sudo) halcompile --install ohmic3.comp
5 years 7 months ago #202736
Try it, it worked for everybody else. I gave you a link to the file to download
There is a lot of documentation in there for the man page that requires other halcompile switches.
- bevins
5 years 7 months ago - 5 years 7 months ago #203235
by bevins
Is there a preference or a link for a suitable 24v isolated power supply? I see in the docs HDR-15-24 but I cant find availability.
Last edit: 5 years 7 months ago by bevins.
- snowgoer540
- Thank you received: 907
5 years 7 months ago #203241
by snowgoer540
From the Plasma Primer:
Here's a link to one in the states (no idea where you are):
www.amazon.com/Meanwell-HDR-15-24-Power-...l%2Caps%2C202&sr=8-6
I didn't understand the importance of using a double insulated class 2 power supply at first. It can not have a path to ground, it must be floating.
Replied by snowgoer540 on topic Hypersensing questions
bevins wrote: Is there a preference or a link for a suitable 24v isolated power supply?
We used a 15W Mean Well HDR-15 Ultra Slim DIN Rail Supply 24V DIN rail based isolated power supply.. This is a double insulated Isolation Class II device that will withstand any arc voltage that might be applied to the terminals.
Time to create page: 0.168 seconds
