Hypersensing questions
5 years 7 months ago #203275 by bevins
Replied by bevins on topic Hypersensing questions
snowgoer540 wrote:
bevins wrote: Is there a preference or a link for a suitable 24v isolated power supply?
From the Plasma Primer:
We used a 15W Mean Well HDR-15 Ultra Slim DIN Rail Supply 24V DIN rail based isolated power supply.. This is a double insulated Isolation Class II device that will withstand any arc voltage that might be applied to the terminals.
Here's a link to one in the states (no idea where you are):
www.amazon.com/Meanwell-HDR-15-24-Power-...l%2Caps%2C202&sr=8-6
I didn't understand the importance of using a double insulated class 2 power supply at first. It can not have a path to ground, it must be floating.
Yeah, thanks, I ordere a meanwell also.
Rodw, will a 1/2watt 24K resistor on the ohmic schematic instead of 5 watt do from the that pulls down the 24v and connects to the -IN on thcad?
I cannot find the 24K 5 watt anywhere. mouser, didgikey, amazon, not in stock anywhere....
5 years 7 months ago - 5 years 7 months ago #203277 by PCW
Replied by PCW on topic Hypersensing questions
20K to 30K should work about the same (approximately 1ma sense current)
25K or 22K are much more common than 24K
5W is important in case of accidental short of the probe to the plasma voltage
(a 1/2W 200V max resistor might explode)
BTW Digikey does have a 24K 5W resistor:
www.digikey.com/en/products/detail/te-co.../ROX5SSJ24K/10231946
Last edit: 5 years 7 months ago by PCW.
5 years 7 months ago #203286 by rodw
Replied by rodw on topic Hypersensing questions
bevins wrote: Is there a preference or a link for a suitable 24v isolated power supply? I see in the docs HDR-15-24 but I cant find availability.
Yeh thats the one. Authoritave link here www.meanwell-web.com/en-gb/ac-dc-ultra-s...dr-15-24%23hdr-15-24
But when I looked it was readily available in all markets. I use RS Components and Element14 (Farnells) who both list it.
I ended up using 5 x 4.7k 1 W resistors in series (23.5k 5 W total) becasue I could buy them locally.
There is nothing accidental, the torch voltage shows up as a full scale reading of the THCAD whenever its cutting. Thats why we use the HDR-15-24 with the THCAD as both are rated to 500 volts.
  • snowgoer540
  • Moderator
  • Moderator
5 years 7 months ago #203288 by snowgoer540
Replied by snowgoer540 on topic Hypersensing questions
Here's a link to the one I used from Mouser: www.mouser.com/ProductDetail/Vishay-Dale...erfnrke6gR%2Fw%3D%3D
99 in stock :)
5 years 7 months ago #203384 by bevins
Yeah I got them coming. Thanks
At fiurst gl;ance they wre Out of stock wherever I looked.
5 years 7 months ago #203387 by bevins
I ordered the DR-15-24 same except not thin line. Still class II isolation and power supply.
Time to create page: 1.097 seconds
