Photos
6 years 2 months ago #179332 by rodw
Replied by rodw on topic Photos
phillc54 wrote:
snowgoer540 wrote: Also, I'm one of those guys who leaves the CNC machine void of all programs that aren't required to run the table. Probably came from the Mach3 days when the computer could hardly handle Mach3 let alone anything else.
My thoughts exactly, a machine controller is a machine controller.
Does anyone use a touch screen, if so what resolution?
I use one 1920 x 1080 with Gmocappy. I really wanted a smaller one but the price was right.
And another new addition to the CNC machine collection has touch but I guess I should not mention Windows 7 on this forum.
6 years 1 month ago #183323 by dvn4life1972
Replied by dvn4life1972 on topic Photos
Just got the machine back up and running with Plasmac again but on a new PC.
1/4in A36 HRS.
The following user(s) said Thank You: phillc54, tommylight, arcsynapse89
6 years 1 month ago #183324 by tommylight
Replied by tommylight on topic Photos
15mm thick mild steel, 24mm holes, cut with Trafimet torch and consumables, nozzle orifice 1.4mm, cut at 85A and 600mm/m.
No pictures of the finished part as there were over 20 people around the machine by the time it finished the first run of 10 parts.
Very little dross on the underside as can be seen on the first picture.
The following user(s) said Thank You: phillc54, shpatb, dvn4life1972, arcsynapse89
6 years 1 month ago #183343 by tommylight
Forgot to add the video of it being cut.
The following user(s) said Thank You: phillc54, dvn4life1972, arcsynapse89
6 years 1 month ago #183413 by dvn4life1972
6 years 4 weeks ago #184592 by dvn4life1972
Some parts using tabs to connect small pieces. 3/16 cold roll(ish), 5in wide flat bar, hypertherm powermax 1000 g3 with duramax retrofit torch.
The following user(s) said Thank You: phillc54, tommylight, Clive S, rodw, pinder, arcsynapse89
