Please help with plasmac configuration
  • pkasy
  • pkasy's Avatar Topic Author
  • Premium Member
  • Premium Member
24 Apr 2020 16:23 #165405 by pkasy
Good afternoon.
I used the search, honestly! I ask for help.
I installed the plasmac on a working configuration in which I already worked today. But I decided to install the THC and update the linuxcnc 2.7 to 2.9. There was even a sheet of metal left to continue working. And I didn’t shift anything or change anything.
And then nightmare began.
At first I ascertained through lengthy trials that the configuration did not work as expected when the servodrive began to gallop around. Did the PID parameters just fly off? No, they are read by the program in the wrong order that they are written. It does not accept XYZY, only XYYZ.
Okay, I did that too. And, although the drive parameters were not correct, plasmac lowered his head, ignited the plasma, performed only one line of the program and stopped. But, since the drive began to flutter during operation, I swapped all axes in the config ( XYZY to XYYZ ) and now the drives are stable.
But does not work!
Now the plasmac lowers its head, finds a sheet and refuses to continue to work, motivating this by the fact that the material is too high. The material that worked before.
I probably already changed all the numbers a million times...
material too high for safe traverse.
program is paused.
ohmic probe detected while moving to probe height.
program is paused.
program is paused.
I think I tried all the options. I even changed the maximum and minimum limits on the Z axis, maybe the program does not know how to work in negative numbers. Did not help. What else can be done?
24 Apr 2020 16:30 #165408 by nkp
Replied by nkp on topic Please help with plasmac configuration
What was the reason for the updates?
(2.7 => 2.9)
  • pkasy
  • Premium Member
  • Premium Member
24 Apr 2020 16:32 #165409 by pkasy
Replied by pkasy on topic Please help with plasmac configuration
Just wanted to use PlasmaC + THC
24 Apr 2020 16:34 #165410 by tommylight
Replied by tommylight on topic Please help with plasmac configuration
Screenshots of "run" and "config" panels ?
That point to probe height or Z axis 0 not properly set.
  • pkasy
  • Premium Member
  • Premium Member
24 Apr 2020 16:38 #165412 by pkasy
ok
24 Apr 2020 16:58 #165414 by tommylight
Do you have ohmic probing OR floating switch ?
In the config panel you have ohmic probe offset set at -25, i am not sure that is correct, but Phill knows that better, if he is around.
  • pkasy
  • Premium Member
  • Premium Member
24 Apr 2020 17:02 #165416 by pkasy
Ohmic. I tried ohmic probe offset from 0 to -25.
After sensing Plasma is trying to go even lower. Not up, but down. Somewhere the system changed sign, but where?
It worked fine before uprade.
24 Apr 2020 17:23 #165424 by tommylight
You might want to wait for Phil or Rod to reply to that as i am not sure how that works in PlasmaC.
IIRC, the Z axis 0 should be just below the slats on the table, and home should be at the positive side, but you have it set as for a mill, meaning you have the zero at max height. That might be the reason for probing errors, but i currently have no way of testing that.
  • pkasy
  • Premium Member
  • Premium Member
24 Apr 2020 17:25 #165425 by pkasy
But it works when config is XYZY, and does not when XYYZ.
  • pkasy
  • Premium Member
  • Premium Member
24 Apr 2020 17:48 #165429 by pkasy
Thank you.
