Please help with plasmac configuration
- Thank you received: 7490
Not sure why.But it works when config is XYZY, and does not when XYYZ.
And you are welcomed, always.
- pkasy
- Thank you received: 5
where is the source code of this module?
Again, if you have limit switch/switches on the Z axis, it should be at the top, zero should be just a bit below the material.
- pkasy
min =0, home = 100 ( 50 or 120 or 210), probe height = any.
first of all - it goes up from home position
if home = 210 as usually, it hits limit switch.
ok, home = 100. then it go up to 150, then down.
againg - it works at XYZY. but pid values not in places. I tried calibration, I tried ini. No luck.
max_limit should be how far up your Z axis goes.
- phillc54
- Thank you received: 2100
If you use the jog buttons for the Z axis does it move in the correct direction?
Do your X and Y axes move correctly.
2.8 would be the better version to use unless you are doing any development.But I decided to install the THC and update the linuxcnc 2.7 to 2.9.
Not quite sure what you mean here. Do you have an external THC, you have Mode =1 which is internal THC.Just wanted to use PlasmaC + THC
- pkasy
I tried MODE 0 and 1. Same.
Will move to 2.8
- phillc54
Does the Z move down when going in - on screen and up when going + ?X Y Z move correctly. by jog buttons or by software.
Will move to 2.8
- phillc54
You have a 30mm Probe Height and a -25mm Ohmic Offset, that means when it detects a material with the ohmic probe then it will drive down another 25mm to take up that offset. This does show up a minor bug in that it doesn't report an error if it gets to the Z minimum at this stage, is just sits there waiting... I will fix that bug but it doesn't really affect the operation.
I think you would need to have a Probe Height of around 45mm or so as the way it is you need to catch the material in that 5mm range.
I have tried with (Zmax=0 Zmin=-215) and (Zmax=215 Zmin=0) and (Zmax=107.5 Zmin=-107.5) it worked correctly for all cases.
What sort of ohmic probe do you have with a -25mm offset.
Do you understand what the error messages you posted mean?
linuxcnc.org/docs/2.8/html/plasma/plasma...html#_error_messagesmaterial too high for safe traverse.
ohmic probe detected while moving to probe height.
Just for interests sake I tried these figures and it still worked:
[AXIS_Z]
MAX_LIMIT = -200.0
MIN_LIMIT = -415.0
[JOINT_3]
MAX_LIMIT = -200.0
MIN_LIMIT = -415.0
HOME = -205.0
HOME_OFFSET = -210.0Please Log in or Create an account to join the conversation.
