Please help with plasmac configuration
- pkasy
- Thank you received: 5
25 Apr 2020 11:35 #165533
by pkasy
Replied by pkasy on topic Please help with plasmac configuration
I started an old configuration with XYZY and fixed pid problem.
It works just fine.
Looks like memory variables error.
Z axis is always #2. in XYYZ config linuxcnc takes variables #2, it is Y axis, and use it as Z axis.
now XYZY, #2 is Z axis, everything works.
IMHO
It works just fine.
IMHO
The following user(s) said Thank You: phillc54, tommylight
- pkasy
25 Apr 2020 13:00 - 25 Apr 2020 13:12 #165538
by pkasy
my fault
Last edit: 25 Apr 2020 13:12 by pkasy.
- Thank you received: 4154
25 Apr 2020 20:35 #165575
Replied by rodw on topic Please help with plasmac configuration
What you've experienced is the big change from 2.7 to 2.8 and later 2.9
In V 2.7 axes mappings to joints were hard coded so x=0, y=1, z=2
In 2.8 and on, this is no longer a hard coded relationship and you can wire things up in any order. But the stepgens are still going to need to be allocated int he order they are used 0,1,2,3...)
I think my machine is a YYXZ becasue of earlier decisions with wiring I made.
- phillc54
- Thank you received: 2100
25 Apr 2020 23:15 #165588
by phillc54
Replied by phillc54 on topic Please help with plasmac configuration
@pkasy,
Could you confirm that you fixed this issue and everything is working ok.
- pkasy
26 Apr 2020 02:31 #165615
by pkasy
yes, everything is ok now.
thank you all
thank you all
- phillc54
26 Apr 2020 02:32 #165616
by phillc54
Great, I am glad you got it sorted.
- pkasy
26 Apr 2020 02:33 #165617
by pkasy
I use 5i25 + 7i77 + 4 servos
But the stepgens are still going to need to be allocated int he order they are used 0,1,2,3...)Please Log in or Create an account to join the conversation.
26 Apr 2020 04:54 #165621
Same thing really they will be numbered on your 7i77
I use 5i25 + 7i77 + 4 servosBut the stepgens are still going to need to be allocated int he order they are used 0,1,2,3...)
- Thank you received: 7501
26 Apr 2020 08:54 #165634
Replied by tommylight on topic Please help with plasmac configuration
Yup, they are named analogout0 to 5 on the 7i77.
- pkasy
26 Apr 2020 09:55 #165644
by pkasy
IMHO it must be in doc.
Time to create page: 0.103 seconds
