Help with adding PlasmaC to base config + 7i76e
  • Moderator
  • Moderator
11 May 2020 10:50 #167385 by tommylight
Replied by tommylight on topic Help with adding PlasmaC to base config + 7i76e
h2m_7i76e.0.7i76.0.0.input-07 was already linked to signal probe in. Now what am I doing wrong this time?
Somewhere in the hal file that pin is linked to something twice, so you need to remove one of them.
Most probably probe-in and float switch that was added after ruining the configurator, so if you do have probe0in in hal, delete that line or just omit it by putting # in front of that line.
  • Plasmaguy
  • Plasmaguy's Avatar Topic Author
  • Senior Member
  • Senior Member
11 May 2020 10:58 - 11 May 2020 11:04 #167386 by Plasmaguy
Replied by Plasmaguy on topic Help with adding PlasmaC to base config + 7i76e
If I do a quick search of the file for "hm2_7i76e.0.7i76.0.0.input-07" only 1 result comes up in the the phill hal file I used to replace my machine hal file with.
I assume I was supposed to replace the files I created with configurator with the files provided by phill in his most recent post.
The only edits I've done since replacing the existing 2 files were to replace the obviously erroneous "h2m" with "hm2" and to change the scales from -1 to +1.
Last edit: 11 May 2020 11:04 by Plasmaguy.
  • Moderator
  • Moderator
11 May 2020 11:00 #167387 by tommylight
Are you also using the "new2.hal" file ? It is there, that should be removed.
  • Plasmaguy
  • Senior Member
  • Senior Member
11 May 2020 11:07 - 11 May 2020 11:07 #167388 by Plasmaguy
I don't know what you're asking...I guess my answer is that I deleted the contents from my two machine folders and replaced them with the content given by phill. Whatever he gave me is now on my machine.
Last edit: 11 May 2020 11:07 by Plasmaguy.
11 May 2020 11:07 #167389 by snowgoer540
Replied by snowgoer540 on topic Help with adding PlasmaC to base config + 7i76e
You can find them in phill's most recent post ...he provided the files which I copied and pasted into my machine.
Right but you said you made changes, and Phill’s had “your pin here” that surely you changed.
Help me (us) help you.
  • Plasmaguy
  • Senior Member
  • Senior Member
11 May 2020 11:10 - 11 May 2020 11:18 #167390 by Plasmaguy
1. Took phill's unedited code
2. replaced the content in the existing 2 files in my machine folder (which were generated by plasmac config) with phill's codes
3. after got errors, resolved the first error by editing the erroneous "h2m" with "hm2"
4. next error resolved i edited the encoder scales from -1 (as phill put in the file he posted) to +1 as tommylight said.
5. No other changes have occured.
Last edit: 11 May 2020 11:18 by Plasmaguy.
11 May 2020 11:12 #167391 by snowgoer540
The only edits I've done since replacing the existing 2 files in my machine folder (generated by plasmac config) were to replace the obviously erroneous "h2m" with "hm2" in the code phill gave me, and to change the scales from -1 (as phill put in the file he posted) to +1 as tommylight said.
Did you run configurator at all?
  • Plasmaguy
  • Senior Member
  • Senior Member
11 May 2020 11:17 - 11 May 2020 11:20 #167392 by Plasmaguy
yes i run configurator on my existing/functional base machine files set up with pncconfig.
Last edit: 11 May 2020 11:20 by Plasmaguy.
  • Moderator
  • Moderator
11 May 2020 11:25 #167393 by tommylight
Phill's files, one of them is named "new2.hal", in the contents of that file is the line to be deleted, so wherever you copied the contents of that file, there look for it.
Or open the files one by one and just search for "probe-in" and delete or omit that line, save and test.
The following user(s) said Thank You: Plasmaguy
  • Plasmaguy
  • Senior Member
  • Senior Member
11 May 2020 11:35 #167394 by Plasmaguy
I'll give it a shot but can't help but wonder why these files need to be hand edited to get a working plasma. Isn't that the point of the configurator? I never imagined I would be 4 days chasing this down and still not over the hurdle.
Time to create page: 0.271 seconds
