Help with adding PlasmaC to base config + 7i76e
- Clive S
- Thank you received: 486
11 May 2020 16:52 #167395
by Clive S
As an on looker, There is a lot of guessing going on. I think you need to post all your files from the config folder (I know Phill has sent you files) BUT it would make things clear to the people helping you if you post them. ZIP the folder up if you need and post it.
Replied by Clive S on topic Help with adding PlasmaC to base config + 7i76e
I'll give it a shot but can't help but wonder why these files need to be hand edited to get a working plasma. Isn't that the point of the configurator? I never imagined I would be 4 days chasing this down and still not over the hurdle.
The following user(s) said Thank You: Plasmaguy
- snowgoer540
- Thank you received: 907
11 May 2020 16:59 #167396
by snowgoer540
Then your files could have changed from your edits. Again, it would be easier if you posted your config files here. I’m not sure why your being obstinate when people are actively trying to help you.
Replied by snowgoer540 on topic Help with adding PlasmaC to base config + 7i76e
yes i run configurator on my existing/functional base machine files set up with pncconfig.
- Plasmaguy
11 May 2020 17:02 - 11 May 2020 17:40 #167397
by Plasmaguy
So I commented out the "probe-in" as advised.
Next I got another similar error about the spinena pin which I'm using for torch on so I commented that out.
Now I can load up the plasmac and run my steppers, I have a couple of issues.
1. torch won't turn on/off via either F9/F10 or on the GUI.
2. not getting a float switch signal on the GUI when the float switch closes.
Any ideas guys?
Replied by Plasmaguy on topic Help with adding PlasmaC to base config + 7i76e
I haven't run configurator since I did a fresh reinstall of Mint last night. I didn't begin using phill's files until a couple of hours ago.Then your files could have changed from your edits.
Any ideas guys?
Last edit: 11 May 2020 17:40 by Plasmaguy. Reason: spelling
- Plasmaguy
11 May 2020 17:20 - 11 May 2020 17:39 #167400
by Plasmaguy
I just copied every file I could from my folder generated by plasmac config last night. Some of the files in that folder would not copy to a usb drive; I don't know whether the files that would not copy are relevant or not.
As uploaded, they are currently updated for my machine that is now running plasmac with the exception of the two issues mentioned in my prior post. The hal file I included has been edited by hand per phill's files with further editing necessary to where I can now load plasmac without causing an error report to be generated.
Uploads attached.
Uploads attached.
Last edit: 11 May 2020 17:39 by Plasmaguy.
- Thank you received: 7501
11 May 2020 17:45 #167402
Replied by tommylight on topic Help with adding PlasmaC to base config + 7i76e
Do you have torch enabled on the lower left on the main screen ?
Your files are OK, and spinena is properly connected to torch on.
When you press F9, does the Z axis move downwards ?
- Plasmaguy
11 May 2020 18:09 #167405
by Plasmaguy
I didn't think to home the machine first before trying F9, now it travels down after homing.
As far as the float switch it may be a wiring issue, I'll check there first.
Thank you!
Thank you!
- Plasmaguy
11 May 2020 19:35 #167413
by Plasmaguy
Still haven't figured out the float switch issue.
My old setup used a 5v power wire going to my float switch. When the switch is pressed it sent signal to the input terminal.
Now I'm using the same setup on the mesa board, with my wire landed on input-07 which I believe is pin#8 on TB6. However I am unable to get the GUI to acknowledge the switch when the switch is depressed and 5v is going to TB6 pin#8.
I use
I use
- Thank you received: 5335
11 May 2020 19:56 #167416
Replied by PCW on topic Help with adding PlasmaC to base config + 7i76e
A 5V signal would not be recognised by a 7I76E input, you need a minimum of 60% of the field voltage (14.4V at 24V field voltage)
Normally you would wire:
+24V field voltage --> switch1 --> switch2 --> 7I76E field input
- Plasmaguy
11 May 2020 21:13 - 11 May 2020 21:27 #167423
by Plasmaguy
Okay that explains that, thank you.
In case this thread is of use to someone else in the future, here are some links to the documentation and files I cobbled together to turn an old desktop into a working machine with mesa 7i76e & thcad10.
Linuxcnc plasma basics tutorial:
forum.linuxcnc.org/47-hal-examples/38440...-9-part-video-series
Plasmac tutorial:
linuxcnc.org/docs/devel/html/plasma/plasmac-user-guide.html
Getting & Installing Linux Mint with LinuxCNC:
forum.linuxcnc.org/9-installing-linuxcnc...aver-mint-iso#165631
Connect 7i76e Mesa board to computer via ethernet:
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
Board wiring info:
forum.linuxcnc.org/media/kunena/attachme...DIAGRAM1-12-19LF.pdf
More wiring info:
forum.linuxcnc.org/media/kunena/attachme...9/7i76_Anschluss.pdf
More wiring info:
forum.linuxcnc.org/27-driver-boards/3191...t?start=20#gallery-2
7176e manual:
www.mesanet.com/pdf/analog/thcadman.pdf
THCAD 10 manual:
www.mesanet.com/pdf/parallel/7i76eman.pdf
Plasmac tutorial:
Board wiring info:
More wiring info:
More wiring info:
7176e manual:
THCAD 10 manual:
Last edit: 11 May 2020 21:27 by Plasmaguy.
11 May 2020 21:23 #167424
Edited the above links as the ended up triple each.
Time to create page: 0.127 seconds
