PlasmaC questions new setup
- Clive S
- Thank you received: 486
This will be for a Hypertherm 45 with a cp port and serial port using a Mesa 7i96 + THC-10
I haven't seen the H-cutter or the manual yet, so would the THC-10 go in the control box or bolted to the side of the Hypertherm 45 like I have done before.
Also would you advise getting it to run first without the serial communication then adding that later ?
- Uthayne
- Thank you received: 49
- Thank you received: 4154
Here is something I did up for the 7i96 that may be helpful
Using a THCAD-5 for hypersensing instead of the relay set up for arcOK frees up a couple of scarce I/O pins so you get better limit switch functionality.
- Clive S
My 7i96 + THC-10 are coming on the 26th May so it will cost too much to get a THC-5 at this point.. The del. charge would be about 28 euro. (I know I know probably 10 time less than you)
The guy I am doing the box for has ordered the Hypertherm 45 with a factory fitted serial connection as well it is being shipped straight to me.
So I can test it on my machine. ( I know PITA but I would like to get the config working before I take it over to him)
I have printed off the connection crib sheet but don't see any RS422 stuff on it. Has that been sorted now?
I have flashed 5 HD's not ssd today with Mr helpful Beagle's iso. I can do them in 40 mins now including the updates
- phillc54
- Thank you received: 2100
linuxcnc.org/docs/2.8/html/plasma/plasma...ml#rs485_connectionsI have printed off the connection crib sheet but don't see any RS422 stuff on it. Has that been sorted now?
There is a question mark on the pin numbering on the hypertherm, Stefan is going to check it out.
- thefabricator03
- Visitor
I will, Ill check and post on Monday AUS time.
Rod I thought you had a 7i76e !!
Yeh I do! and a couple of other bits and pieces. I did get as far as putting all this on a bit of DIN rail and partly wired up hence the din rail numbering. I had this idea to make a reference build for the 7i96 that fitted in a plasma cuttable control box.
But its morphed into a massive project with a US manufacturer so we can bring the whole prebuilt control box to market with a preconfigured Plasmac PC. Plus a circuit board/wiring harness I came up with after my experiences building my machine so building a plasma cutter will become a plug and play exercise. And a carefully engineered matched motor and driver pack. Maybe we will need a UK rep!
- Clive S
Yes I did see that on the PowerMax 125. So it seems it might be the same on the 45.
- phillc54
A bit more info on this thread forum.linuxcnc.org/plasmac/37307-rs485-f...rms?start=180#164394
- Clive S
Yeh I do! and a couple of other bits and pieces. I did get as far as putting all this on a bit of DIN rail and partly wired up hence the din rail numbering. I had this idea to make a reference build for the 7i96 that fitted in a plasma cuttable control box.!
Yes, Rod I remember seeing it at your place now. This will be my 5th 7i96 board i have already made the mounting for it.
photos.app.goo.gl/aLPgt1e1Tc1CsZT87
I take it will be all open source
