PlasmaC questions new setup
15 Jun 2020 08:14 #171700 by phillc54
Replied by phillc54 on topic PlasmaC questions new setup
Just compress the complete directory.
15 Jun 2020 08:16 #171701 by tecno
Replied by tecno on topic PlasmaC questions new setup
How, there not to be any Zip
15 Jun 2020 08:20 #171704 by tecno
Novice here :(
File Name: tecnoplasma.zip
File Size:568 KB
15 Jun 2020 08:20 #171705 by phillc54
Right click on the file and then click Compress
15 Jun 2020 08:32 #171707 by phillc54
Try changing these in the Config Panel:
Probe Speed 400
Probe Height 40
Safe Height 40
Setup Speed 2000
15 Jun 2020 08:33 #171708 by rodw
Replied by rodw on topic PlasmaC questions new setup
You can sort this out doing a G54 touchoff.
I have 86mm travel so I went to the top of travel and touched off the Z axis at 86mm and I've never touched it for years. That means that it is 0.0 at the bottom of travel
15 Jun 2020 08:48 #171710 by tecno
Pling.............................................. G54
Looks as it works now. Need to do some maintenance as all 4 screws holding the stepper where ripped out LOL Made some errors obviously.
Problem must be the fixed value 40 of feedrate in Run Panel.
Where do I set Safe Height?
15 Jun 2020 09:05 #171715 by phillc54
In the Config Panel, top right.
15 Jun 2020 09:22 #171717 by tecno
Happy too early, now its the same as before Z stand still when it should go down and touch off and start cutting.
15 Jun 2020 09:24 #171718 by phillc54
Did you change all the settings I posted. When I changed them to that here it worked fine. You then need to save them.
