PlasmaC questions new setup
13 Jun 2020 19:25 - 13 Jun 2020 19:25 #171471 by tecno
Replied by tecno on topic PlasmaC questions new setup
I managed to find a 64GB µSD at home = mediacard in my mobilephone :)
So a copy of the image boots OK and even after Gparted expansion I now have 54GB free space.
Last edit: 13 Jun 2020 19:25 by tecno.
13 Jun 2020 19:39 #171472 by tecno
Missed this one at start up
I have now checked all INI files and all are the same as regards [TRAJ], so this error message puzzles me.
13 Jun 2020 19:41 #171473 by tecno
You need a valid Cut Speed in the Run Panel before you load/create/reload the file.
I have now checked this issue several times and I can not set any feedrate in Run Panel.
  • Moderator
  • Moderator
13 Jun 2020 20:04 #171477 by tommylight
Replied by tommylight on topic PlasmaC questions new setup
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = metric <<<<<< this
ANGULAR_UNITS = degree
MAX_LINEAR_VELOCITY = 100
LINEAR_UNITS = mm
Sorry i missed it the first go around.
The following user(s) said Thank You: tecno
13 Jun 2020 20:09 #171478 by tecno
And I am the novice ;)
13 Jun 2020 20:18 #171481 by tecno
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = mm
That took care of the other issue also, now I can set Feedrate in Run Panel
Getting closer
13 Jun 2020 20:48 #171488 by rodw
Replied by rodw on topic PlasmaC questions new setup
Novice!!!
You can't use that excuse anymore. This is your second machine! :silly: :silly:
13 Jun 2020 22:01 #171506 by tecno
3:rd but still novice in LCNC world
  • Moderator
  • Moderator
13 Jun 2020 22:18 #171510 by tommylight
Yes, 3rd and ...... wait, what?
13 Jun 2020 23:36 #171515 by phillc54
Replied by phillc54 on topic PlasmaC questions new setup
Sorry I was a bit late for all this...
Good to see you got it going.
From the menu, System > Administration > Raspi Config > Advanced Options > Expand Filesystem
The [TRAJ] error would have prevented PlasmaC from loading its configuration correctly.
Time to create page: 0.154 seconds
