PlasmaC questions new setup
- Thank you received: 7449
14 Jun 2020 21:02 #171641
Replied by tommylight on topic PlasmaC questions new setup
Here is what i have:Also noticed your hal and ini file have some strange settings and values, but should work.
HOME = 160.0
FERROR = 10.0
MIN_FERROR = 1.0
MIN_LIMIT = 0
MAX_LIMIT = 170.0
HOME_OFFSET = 170.000000
HOME_SEARCH_VEL = 30.000000
HOME_LATCH_VEL = 3.00000
HOME_FINAL_VEL = 30.000000
- Clive S
- Thank you received: 486
14 Jun 2020 21:07 #171642
by Clive S
Replied by Clive S on topic PlasmaC questions new setup
Does the probe test button work?
Can you re post your hal and ini file now you have modified them including the io.hal file.
Have you actually put a feed rate in the run config. Can you show a screen shot of the run and config tabs
- tecno
- Thank you received: 127
14 Jun 2020 21:12 #171644
by tecno
Replied by tecno on topic PlasmaC questions new setup
Hmmm you have only positive numbers,
Must be something odd in my settings
14 Jun 2020 22:10 #171649
Phill uses only negative values and it works for him, so that is not important.
The important part is how those settings are related and how any of them can mess the Z axis functioning.
I did that so i can always have a look at dro and know exactly how high the torch is in relation to the material surface, even during cutting.
- tecno
14 Jun 2020 22:18 #171651
by tecno
What puzzles me that all axis work as I want them to do.
X/Y pos values from 0,0,0 and negative on Z. Like a milling machine, you move the tool.
Maybe I am wrong ?
Maybe I am wrong ?
14 Jun 2020 23:06 #171654
This is what worked for me, after half a day of messing with values.
And this is not for a mill, so the torch will never be under the material height, hence no need for negative values.
No, you are not wrong.Maybe I am wrong ?
- phillc54
- Thank you received: 2100
15 Jun 2020 00:39 - 15 Jun 2020 00:39 #171662
by phillc54
Replied by phillc54 on topic PlasmaC questions new setup
Can you zip your config folder directory and post it then I can give it a run here.
Last edit: 15 Jun 2020 00:39 by phillc54.
- tecno
15 Jun 2020 07:51 #171696
by tecno
- phillc54
15 Jun 2020 07:58 #171697
by phillc54
That looks like your base machine, I need the complete directory that the Configurator created.
- tecno
15 Jun 2020 08:08 #171699
by tecno
Sorry,
but I can not copy my plasmaC config, copy does not accept .py etc
Time to create page: 0.152 seconds
