Help with homing on dual axis PlasmaC
- Clive S
- Thank you received: 486
16 Jul 2020 21:43 - 16 Jul 2020 21:53 #174887
by Clive S
Help with homing on dual axis PlasmaC was created by Clive S
Please see the vid for the problem with the homing one side stutters and and the other side is fine and homes without stutter.
The motors are closed loop servos. The machine is grounded correctly.
After it homes it jogs perfectly at 15M/min
There is no binding on the screw
could it be this setp pid.y2.maxerror .0005
is the debounce correctly setup ?
Last edit: 16 Jul 2020 21:53 by Clive S. Reason: added text
- phillc54
- Thank you received: 2100
16 Jul 2020 23:25 #174892
by phillc54
Replied by phillc54 on topic Help with homing on dual axis PlasmaC
You haven't connected the debounce outputs, instead of:
you need something like:you could probably also setp the debounce delay a lot lower
net home-y => joint.0.home-sw-in
and
net home-y2 => joint.0.home-sw-inyou need something like:
net home-y-out debounce.0.0.out => joint.1.home-sw-in
and
net home-y2-out debounce.0.1.out => joint.2.home-sw-in
- Clive S
17 Jul 2020 07:22 #174908
by Clive S
Thanks Phill
Are the timings for debounce in nano or usecs
Replied by Clive S on topic Help with homing on dual axis PlasmaC
net home-y => joint.0.home-sw-in and net home-y2 => joint.0.home-sw-in
you need something like:you could probably also setp the debounce delay a lot lowernet home-y-out debounce.0.0.out => joint.1.home-sw-in and net home-y2-out debounce.0.1.out => joint.2.home-sw-in
Thanks Phill
- Thank you received: 7501
17 Jul 2020 07:24 #174910
Replied by tommylight on topic Help with homing on dual axis PlasmaC
Those lines should be deleted or omitted, in most cases.could it be this setp pid.y2.maxerror .0005
- phillc54
17 Jul 2020 07:27 #174911
by phillc54
I believe they are servo periods, so usually 1 mS per period.Are the timings for debounce in nano or usecs
- phillc54
17 Jul 2020 07:28 #174912
by phillc54
Do they cause issues? I see that I have the same in my config.
@Tom
- Clive S
17 Jul 2020 07:35 #174913
by Clive S
I have seen PCW say delete them many time for stepper configs not sure about close loop servos
@Tom
- Clive S
17 Jul 2020 07:40 #174914
by Clive S
Is this correct then:-
# --- HOME-Y ---
net home-y <= hm2_7i96.0.gpio.003.in_not
net home-y debounce.0.0.in
net home-y-out => joint.1.home-sw-in
Thanks Phill
# --- HOME-Y ---
- phillc54
17 Jul 2020 07:42 #174917
by phillc54
Yep, that looks OK.Is this correct then:-
# --- HOME-Y ---
17 Jul 2020 07:52 #174921
PCW also showed when that line would be useful, but i can not find the topic, it was about 7 or more months ago.
Yes on stepper systems, not sure about servo, but since it is a step/dir system, chances are they have to be removed. They case instability/vibrations/errors on position tracking. I got used to just deleting them.
@Tom
Time to create page: 0.980 seconds
