Help with homing on dual axis PlasmaC
16 Jul 2020 21:43 - 16 Jul 2020 21:53 #174887 by Clive S
Help with homing on dual axis PlasmaC was created by Clive S
Please see the vid for the problem with the homing one side stutters and and the other side is fine and homes without stutter.
The motors are closed loop servos. The machine is grounded correctly.
After it homes it jogs perfectly at 15M/min
There is no binding on the screw
could it be this setp pid.y2.maxerror .0005
is the debounce correctly setup ?
File Name: test.ini
File Size:5 KB
File Name: test.hal
File Size:10 KB
Last edit: 16 Jul 2020 21:53 by Clive S. Reason: added text
16 Jul 2020 23:25 #174892 by phillc54
Replied by phillc54 on topic Help with homing on dual axis PlasmaC
You haven't connected the debounce outputs, instead of:
net home-y     =>  joint.0.home-sw-in
and
net home-y2     =>  joint.0.home-sw-in
you need something like:
net home-y-out   debounce.0.0.out  =>  joint.1.home-sw-in
and
net home-y2-out  debounce.0.1.out  =>  joint.2.home-sw-in
you could probably also setp the debounce delay a lot lower
17 Jul 2020 07:22 #174908 by Clive S
Replied by Clive S on topic Help with homing on dual axis PlasmaC
and
and
Thanks Phill
Are the timings for debounce in nano or usecs
17 Jul 2020 07:24 #174910 by tommylight
Replied by tommylight on topic Help with homing on dual axis PlasmaC
Those lines should be deleted or omitted, in most cases.
17 Jul 2020 07:27 #174911 by phillc54
I believe they are servo periods, so usually 1 mS per period.
17 Jul 2020 07:28 #174912 by phillc54
@Tom
Do they cause issues? I see that I have the same in my config.
17 Jul 2020 07:35 #174913 by Clive S
@Tom
I have seen PCW say delete them many time for stepper configs not sure about close loop servos
17 Jul 2020 07:40 #174914 by Clive S
and
and
Thanks Phill
Is this correct then:-
# --- HOME-Y ---
net home-y <= hm2_7i96.0.gpio.003.in_not
net home-y debounce.0.0.in
net home-y-out => joint.1.home-sw-in
17 Jul 2020 07:42 #174917 by phillc54
# --- HOME-Y ---
Yep, that looks OK.
17 Jul 2020 07:52 #174921 by tommylight
@Tom
Yes on stepper systems, not sure about servo, but since it is a step/dir system, chances are they have to be removed. They case instability/vibrations/errors on position tracking. I got used to just deleting them.
PCW also showed when that line would be useful, but i can not find the topic, it was about 7 or more months ago.
Time to create page: 2.179 seconds
