Feature Request
6 years 2 months ago #179176 by snowgoer540
Replied by snowgoer540 on topic Feature Request
phillc54 wrote:
Ok I can make those changes in the morning if you’d like and I’ll attach them here.
All good, I can do it here. I just copied and pasted yours into the docs and made those two changes. Thanks again.
New release? I don’t follow along at that level so I’m not sure what’s going on with LinuxCNC itself.
2.8 is in final testing and about to be released. Once it is released then new features won't appear in the distribution ISO until the next point release (2.8.1) I want to get CR in 2.8 before release and there will not be enough time to add the code so it can be on the main GUI screen and test it out thoroughly.
Having said that if you use Buildbot builds then any additions will be available immediately. Not half confusing is it?
Sounds good, thanks! The doc in the next post looked good too.
Truthfully, I don’t understand the LinuxCNC release schedules/cycles. It’s a lot to wrap your head around because currently I count 3 different versions out there. 2.7, 2.8, and 2.9. Not sure I could point out what’s different among them. Other than 2.7 doesn’t have reverse run stuffs.
As for me, I’ll just stick to what I’ve been doing until someone tells me not to :laugh:
I still plan to go through the user guide and proof read whenever we get a rainy day... have had none so far despite the threat. Just hot.
6 years 2 months ago #179177 by snowgoer540
phillc54 wrote: User Guide extract
Next I’ll have to learn the magic hidden text post trick lol
6 years 2 months ago - 6 years 2 months ago #179179 by phillc54
Replied by phillc54 on topic Feature Request
it is the icon to the right of spoiler (looks like a shield)
Edit: I used it accidently instead of spoiler...
Last edit: 6 years 2 months ago by phillc54.
6 years 2 months ago #179185 by phillc54
CR has been pushed to 2.8 and master so you can switch back to either branch.
I will remove the test branch tomorrow.
6 years 2 months ago #179208 by snowgoer540
phillc54 wrote: CR has been pushed to 2.8 and master so you can switch back to either branch.
They just grow up so fast! :lol:
Sounds good, I’ll switch back this evening. Been a pleasure testing this!
6 years 2 months ago #179213 by phillc54
snowgoer540 wrote: Sounds good, I’ll switch back this evening. Been a pleasure testing this!
Thank you for testing. Your results were what I was hoping for.
Time to create page: 0.098 seconds
