Some thoughts and some findings using PlasmaC
- Thank you received: 7491
That being said, most of what is written bellow is my fault for building very fast machines, and that brings the first issue:
-using speeds of over 3m/m for the Z axis will very often over run the soft and/or hard limits requiring to switch to joint mode and jog the Z axis down manually, then back to world mode to continue work.
-probe/floating switch is active only during auto mode, so bumping the torch into something while jogging will not stop the machine. It would be safer to have it active all the time.
-in portrait mode the jog speed is stuck at the highest value, in my case at 36m/m, while the jog slider is where it should be and moving the slider will set the speed correctly. Not sure if this is PlasmaC or Axis GUI issue, will do some more tests and report back.
Another feature already discused with Phill is ignoring the float switch from the moment the torch on singal is active till the arcok goes true. This is to awoid arc lost issues caused by unshielded and cheap proximity sensors as they are usually located near the torch and i did encounter that issue.
As for what works, well everything i did test works perfectly, THCAD tracks the material smooth and fast, Proma THC works nicely in mode 2 and the tracking speed can be adjusted to awoid "bunny hopping" the torch, materials work perfectly setting the feed rate and all the parameters, touch off button (when added) works and reloads the part in gremlin makes using a laser for edge finding a single button affair, load sheet works, change consumables works and can be set as needed, pierce/cut feature works and is very usefull for thicker material to save consumables as one can use old consumables for piercing and new ones for cutting. Yes, nozzles will get messed up when piercing, shortening their life.
Everything i did test works, so thank you Phill for the amazing work, and thanks to all who contributed and helped in developing this magnificent piece of software and hardware ( looking at you PCW ) .
Regards,
Tom.
- phillc54
- Thank you received: 2100
Does that happen with Z moving down, up or both?-using speeds of over 3m/m for the Z axis will very often over run the soft and/or hard limits requiring to switch to joint mode and jog the Z axis down manually, then back to world mode to continue work.
It is active, as is breakaway. They just don't do anything. It would be possible to issue a feed hold but I guess we would also need to pop up a warning otherwise it may cause confusion.-probe/floating switch is active only during auto mode, so bumping the torch into something while jogging will not stop the machine. It would be safer to have it active all the time.
I'll have a look tomorrow, it is probably something dumb that I did.-in portrait mode the jog speed is stuck at the highest value, in my case at 36m/m, while the jog slider is where it should be and moving the slider will set the speed correctly.
I have done a bit of work on that but I need to figure out how to build in compatibility for users who have a combined float/breakaway switch, namely me.Another feature already discused with Phill is ignoring the float switch from the moment the torch on singal is active till the arcok goes true. This is to awoid arc lost issues caused by unshielded and cheap proximity sensors as they are usually located near the torch and i did encounter that issue.
- Thank you received: 4152
Any crash sensing needs to be restricted to the float switch because any users using hypersensing will not be able to use the ohmic probe as it will see the arc voltage (by design) while cutting.
I've never had problems with the z axis but its not fast yet.
I guess I've been pretty successful incorporating suggestions in to Plasmac so thanks Phill for that.
Issues of concern for me are:
1. Upgrade process broken my config and duplicated ini file entries. Whilst it might be great for a new user starting with the release of 2.8, my config is not that old so I found that frustrating. Some pin conlficts I resolved were with (much) earlier pncconf settings.
2. Solely dependent on Phil to manage the code base. As more plasma centric features are added to Linuxcnc which potentially obsolete some of Phill's hard work, he might not want to do the rework to improve the code. He's off the hook now but I have lots of ideas on how to take what we are doing to the next level. Look out if I ever retire!
3. Lack of end points to integrate custom features. There is a lot of work to unhook stuff cleanly to extend Plasmac. At a minimum, there should be a hold THC input pin available for the user. What if Stivemaster13 wants to override torch height while cutting holes?
That will do for now, I need Phill in the morning
UP, during cutting, when esc is pressed, after several cuts, seems like a cumulative error.Does that happen with Z moving down, up or both?
On my config it will disable everything requiring F2 to be pressed to continue, also an error is reported as joint3 in my case.It is active, as is breakaway. They just don't do anything. It would be possible to issue a feed hold but I guess we would also need to pop up a warning otherwise it may cause confusion.
Just checked, in landscape mode it is OK.I'll have a look tomorrow, it is probably something dumb that I did.
Ignoring both will not do any harm as the machine will never be moving while that ignore is active.I have done a bit of work on that but I need to figure out how to build in compatibility for users who have a combined float/breakaway switch, namely me.
It's such a nice club !I really have to agree its an amazing body of work. After joining Tommy's high acceleration club,
Will not affect that as it should be ignoring signals from torch on to arc ok.Any crash sensing needs to be restricted to the float switch because any users using hypersensing will not be able to use the ohmic probe as it will see the arc voltage (by design) while cutting.
Close LinuxCNC before upgrading or reconfiguring the configs, bumped into that a few days back. Having LinuxCNC running will mess up the config as it can not read and write stuff it needs to.1. Upgrade process broken my config and duplicated ini file entries. Whilst it might be great for a new user starting with the release of 2.8, my config is not that old so I found that frustrating. Some pin conlficts I resolved were with (much) earlier pncconf settings.
It already does that by itself when corner lock is active. Seen it work. If you mean to adjust the torch while cutting that is different, but then again it can be done by changing the voltage while running.3. Lack of end points to integrate custom features. There is a lot of work to unhook stuff cleanly to extend Plasmac. At a minimum, there should be a hold THC input pin available for the user. What if Stivemaster13 wants to override torch height while cutting holes?
Getting suspicious here !That will do for now, I need Phill in the morning
- phillc54
I have several different versions of configs that I keep here from PlasmaCs release until the latest version so that I can test updates. If there are no changes to standard PlasmaC files then all should go well. When you post the new config tomorrow can you post a copy of your config before updating so I can see what happens during an upgrade.Issues of concern for me are:
- snowgoer540
- Thank you received: 907
Interesting, I've mentioned similar to Phill. I think I see this as well, it manifests as joint 3 following error for me, and it's the only axis (Z) I have trouble with, and it's ONLY in the up direction, and only when PlasmaC is in charge of the torch.
Manually, I can jog (rapid) the torch until I'm blue in the face and I never get an error, it's only when PlasmaC is in charge, and only in the up direction. Also, my accelerations and speeds are higher for the other axis' and I don't see following errors.
I concur that lowering the acceleration and setup speeds does make it less likely to occur. Right now Z is pretty tame, but what I built is capable of much more.
At any rate, just wanted to drop that in here in case it helps at all.
Manually, I can jog (rapid) the torch until I'm blue in the face and I never get an error,........
- snowgoer540
Haha, what's that mean? Or are you just happy at the though of my torch jogging
Nah, i just imagined you blue in the face !
