Configure PlasmaC with only one BOB
- Giuseppe
- Thank you received: 9
pin parport.0.pin-11-in-not was already linked to all-home
I think this is because i used one pin for homing and for THC ?
You can try:
net all-home debounce.0.2.inie, re-use the signal.
- Giuseppe
- Clive S
- Thank you received: 486
Sorry, i can't find information how to re-use the signal.
net all-home => joint.2.home-sw-in ..... from the hal file the bit in blue is the signal
.Andy wrote You can try:
ie, the signal can be reused for the debounce
- Giuseppe
I will change
"net din-001 parport.0.pin-11-in-not => debounce.0.2.in"
from the connections.hal to
"net all-home parport.0.pin-11-in-not => debounce.0.2.in"
and
"net din-001<= debounce.0.2.in"
in the hal file to
"net all-home <= debounce.0.2.in"
- Giuseppe
So far so good.
Now i have to fix the EHC enable. This is still on when i start plasmac.
I will try it by my own
- Giuseppe
setp parport.0.pin-16-out-invert 1
but it doesn't work
OK does i understand it right?
I will change
and
in the hal file to
A HAL "net" command is
net signal_name hal_pin1 hal_pin2 hal_pin3
With as many hal pins as you want in the net.
The signal name can be anything you want. It should be something that makes sense to you.
The following all do the same thing.
net signal_name parport.0.pin-11-in joint.0.home-sw-in joint.0.max-lim joint.0.min-lim debounce.0.2.inor
net signal_name joint.0.home-sw-in joint.0.max-lim joint.0.min-lim
net signal_name debounce.0.2.inOr any variant of that. spread between as many HAL files as you want.
When you tried to re-use parport.0.pin-11-in the system told you that the pin value was already available on the signal "all-home".
A pin can only be connected to one net. But many pins can be connected to the same net.
So if you want to use the value of that pin somewhere else, you re-use the signal name.
Your code above seems to be rather confused.
- Giuseppe
I think i understand what you are talking about. I hope so
At this moment i think it works not completely right.
When i start plasmac, should the "thc enabled" LED light up? In my case it is so. How can i turn it of for test?
When i use the M64 M65 nothing happens.
Another think thats work is the "Probe test" button. When i click it, the z axis go down until it touches the bed. Then it counts a timer and after this it go back to start position. Is this right function?
Can help someone?
- snowgoer540
- Thank you received: 907
Without seeing your gcode it's hard to say. You can disable it manually in the RUN PANEL (or TAB depending how you have it configured). linuxcnc.org/docs/devel/html/plasma/plasmac-user-guide.html#thcBack to my cutter.
Yes, but there is more to it, after it probes, it is stopping at "pierce height" for the currently selected material. It pauses there so that you can use a gauge block, or feeler gauges, or similar, to measure that the pierce height is accurate. This allows you to compensate for the movement in the float switch. This moment can be compensated for in the config tab under "float travel" in the probing section. linuxcnc.org/docs/devel/html/plasma/plas...e.html#_config_panelAnother think thats work is the "Probe test" button. When i click it, the z axis go down until it touches the bed. Then it counts a timer and after this it go back to start position. Is this right function?
You would keep adjusting this value until the pierce height on the currently displayed material = the pierce height you measure in real life.
linuxcnc.org/docs/devel/html/plasma/plas...de.html#button-probe
