Configure PlasmaC with only one BOB
- phillc54
- Thank you received: 2100
15 Apr 2021 21:08 - 16 Apr 2021 03:38 #206078
by phillc54
Replied by phillc54 on topic Configure PlasmaC with only one BOB
Can you confirm the following:
You do not have a breakaway switch.
You do not have a float switch.
You are using "parport.0.pin-11-in-not" for all-home and also for ohmic-probe-input.
What version of LinuxCNC are you using?
Edit:
You seem to be using an old version of PlasmaC, the debounce component was changed to the new dbounce component on September 11 last year.
Edit:
Last edit: 16 Apr 2021 03:38 by phillc54.
- Giuseppe
- Thank you received: 9
18 Apr 2021 13:54 #206321
by Giuseppe
Replied by Giuseppe on topic Configure PlasmaC with only one BOB
YES (will come later)
YES
Version is 2.8.0
YES
Version is 2.8.0
- phillc54
18 Apr 2021 20:38 #206347
by phillc54
Try the two attached files, hopefully I got it correct. There are a couple of comments in the testplasmacnc_connections.hal that are dependant on whether you need a "in" or "in-not" for ohmic probing.
It is best when using PlasmaC to keep all your plasma specific connections in the testplasmacnc_connections.hal file which allows you to use StepConf to change config settings without changing any plasma connections.
- Giuseppe
16 May 2021 06:18 #209068
by Giuseppe
Thanks for the help.
I decided to make ohmic sensor later.
I have now built a floating switch for start. Can someone tell me how the line in the connection.hal must look if the switch is connected to pin 11?
- phillc54
16 May 2021 06:22 #209069
by phillc54
net plasmac:float-switch parport.0.pin-11-in => debounce.0.0.in
- Giuseppe
16 May 2021 06:37 #209073
by Giuseppe
i will try it immediately
- Giuseppe
16 May 2021 07:16 - 16 May 2021 07:17 #209082
by Giuseppe
ok it looks good. but i have to invert the signal.
If i do it, than i get message "...was already linked to signal XXX
Last edit: 16 May 2021 07:17 by Giuseppe.
- phillc54
16 May 2021 07:20 #209084
by phillc54
Do you still have it linked to ohmic probe?
If so you will need to comment that line.
- Giuseppe
16 May 2021 07:24 - 16 May 2021 07:25 #209086
by Giuseppe
no, the pin is linked to my home switch
net all-home <= parport.0.pin-11-in-not
Last edit: 16 May 2021 07:25 by Giuseppe.
- phillc54
16 May 2021 07:36 - 16 May 2021 07:36 #209088
by phillc54
Try this instead:
net all-home => dbounce.0.0.in
Or change the contacts of the float switch.
Last edit: 16 May 2021 07:36 by phillc54.
Time to create page: 0.133 seconds
