Configure PlasmaC with only one BOB
  • Giuseppe
  • Giuseppe's Avatar Topic Author
  • Premium Member
  • Premium Member
16 May 2021 08:11 #209091 by Giuseppe
Replied by Giuseppe on topic Configure PlasmaC with only one BOB
oh man, this makes me crazy.
When i try net all-home => debounce.0.0.in
then i get the error debounce0.0.in is allreday linked
The contacts i can't change.because the float switch is triggering my home switch then.
i have to invert the float switch signal in plasmac
16 May 2021 18:25 #209182 by phillc54
Replied by phillc54 on topic Configure PlasmaC with only one BOB
If you add this line then you would need to comment out the earlier line that links debounce.0.0.in
How are your home switches and float switch wired?
  • Giuseppe
  • Premium Member
  • Premium Member
17 May 2021 02:10 #209196 by Giuseppe
What debounce mean? For what it is?
  • Giuseppe
  • Premium Member
  • Premium Member
17 May 2021 11:12 #209239 by Giuseppe
My home switches are induction switches. I connected them with some relays.
The relays are connected to the input pins of my board.
I used pin 10 and pin 11 for homing.
I used a microswitch for the floating switch. This one is connected to pin 11 of my homing.
This is the current hal files.
# Generated by stepconf 1.1 at Fri Dec 25 19:31:57 2020
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0
addf stepgen.update-freq servo-thread
# net spindle-cmd-rpm     <= spindle.0.speed-out
# net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
# net spindle-cmd-rps     <= spindle.0.speed-out-rps
# net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
# net spindle-at-speed    => spindle.0.at-speed
net xstep           => 				parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net xdir            => 				parport.0.pin-03-out
net ystep           => 				parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-05-out-invert 1
net ydir            => 				parport.0.pin-05-out
net zstep           => 				parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
setp parport.0.pin-07-out-invert 1
net zdir            => 				parport.0.pin-07-out
net y1step          => 				parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
setp parport.0.pin-09-out-invert 1
net y1dir           => 				parport.0.pin-09-out
net xenable         => 				parport.0.pin-14-out
net all-home        <= 				parport.0.pin-11-in-not
net home-y1         <= 				parport.0.pin-10-in-not
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net all-home => joint.0.home-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net home-y1 => joint.1.home-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net y1pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net y1pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net y1step <= stepgen.2.step
net y1dir <= stepgen.2.dir
net y1enable joint.2.amp-enable-out => stepgen.2.enable
net all-home => joint.2.home-sw-in
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 35000
setp stepgen.3.dirsetup 35000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net zstep <= stepgen.3.step
net zdir <= stepgen.3.dir
net zenable joint.3.amp-enable-out => stepgen.3.enable
net all-home => joint.3.home-sw-in
net estop-out => iocontrol.0.emc-enable-in
# loadusr -W hal_manualtoolchange
# net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
# net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
# net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
# net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# toolchange passthrough
net tool:change iocontrol.0.tool-change  => iocontrol.0.tool-changed
net tool:prep   iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# Keep your plasmac i/o connections here to prevent them from
# being overwritten by updates or pncconf/stepconf changes
# Other customisations may be placed here as well
# This file is built by the configurator in your configuration directory
#***** debounce for the float, ohmic and breakaway switches *****
# the lower the delay here the better
# each 1 is a 0.001mm (0.00004") increase in probed height result
loadrt  debounce          cfg=3
setp    debounce.0.delay  5
addf    debounce.0        servo-thread
#***** arc voltage lowpass cutoff frequency *****
#***** change to the cutoff frequency you require *****
setp plasmac.lowpass-frequency 0
#***** the joint associated with the Z axis *****
net plasmac:axis-position  joint.3.pos-fb  =>  plasmac.axis-z-position
net plasmac:arc-ok-in  parport.0.pin-15-in-not  =>  plasmac.arc-ok-in
# net plasmac:float-switch  {YOUR FLOAT SWITCH PIN}  =>  debounce.0.0.in
# net plasmac:breakaway  {YOUR BREAKAWAY PIN}  =>  debounce.0.1.in
net plasmac:torch-on  		=>  	parport.0.pin-17-out
net plasmac:ohmic-enable  	=>  	parport.0.pin-16-out
net plasmac:move-down  				parport.0.pin-13-in  	=>  	plasmac.move-down
net plasmac:move-up    				parport.0.pin-12-in  	=>  	plasmac.move-up
### THIS NEEDS TO GO TO AN PARPORT OUTPUT TO ENABLE THE OHMIC PROBE CIRCUIT ###
# a 1 here allows multiple tools to be used
# gcode M3 S1 needs to be changed to:
# M3 $0 S1 for the plasma torch
# M3 $1 S1 for the scribe
# M3 $2 S1 for spotting
setp plasmac.multi-tool 0
# net plasmac:scribe-arm plasmac.scribe-arm => ***YOUR_SCRIBE_ARMING_OUTPUT***
# net plasmac:scribe-on  plasmac.scribe-on  => ***YOUR_SCRIBE_ON_OUTPUT***
With this configuration the homing works fine.
If i make this change "net plasmac:float-switch parport.0.pin-11-in-not => debounce.0.0.in"
Then i get the error that the pin is linked to all-home.
If i change all-home to "all-home => debounce.0.0.in"
then i get the error "debounce is linked to"
Time to create page: 0.179 seconds
