- Thank you received: 907
Latest QtPlasmaC on Debian "Unstable", here is a strange one:
-home all
-wizard, 50x25mm box, inside leadin 4mm, 5mm radii on all corners
-wizard multiply at 5 columns 2 rows with 55 and 30 offsets
-send
-run
-stop using esc or cancel
-run again = it moves the start point to the second box
-stop again
-run again = it moves to start point to the third box
-rinse and repeat
-if left to continue, it will do all boxes, but they will not be where they should.
