QtPlasmaC release.
4 years 5 months ago #242924 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
Keep in mind this is on Unstable Debian, so needs more testing.
Debian Bookworm, QtPlasmaC v1.223-181 i think, same version on two different PC's, both lock GUI solid at random, today on one, a few days back on the other. On both cases everything else runs normally, even milltask and Python3 are all good.
Unstable is the correct word, I have issues running Debian Unstable as a VM, until that works reliably I won't be looking at this issue.
4 years 5 months ago #244086 by tommylight
Replied by tommylight on topic QtPlasmaC release.
The LinuxCNC Debian repo is not getting updated lately, so i am still testing the above version.
One of the old issues is still present, namely the not firing the torch at all, probes ok, goes to pierce height and nothing. Whenever this happens it will not fire several tries, then it will fire and continue OK. No restart or reboot, just run from line, stop, run from line.
The other issue, if arc stops, sometimes (about 1 in 30) it will continue to run despite the ARCOK going off and voltage showing 0. This is still in mode 0, never noticed in mode 1.
And why is there no "send" for MDI? I have to find the virtual keyboard and click enter, what a drag! :) Yeah, using touch screen, 23" of it, and that brings another "my" issue: does not have bigger letters as PlasmaC did, but i guess this is same as with buttons and other stuff that are fixed. Any hope for a full HD version soon?
Oh, and GUI locked solid again today, on another PC, so that makes 3 different PC's.
4 years 5 months ago - 4 years 5 months ago #244088 by phillc54
Does the TORCH ON LED turn on when the torch does not fire?
Does this happen on PlasmaC as well?
Would it help if the soft keyboard appeared when MDI was selected? I see that is not the case presently.
I don't have any plans for one at this stage, I don't have a HD monitor to develop on nor the time at the moment. It would be a good project for someone who wanted to contribute.
No odd numbers in HTOP? It would possibly show up in a line beginning with /usr/bin/python
Last edit: 4 years 5 months ago by phillc54.
4 years 5 months ago #244089 by tommylight
I am not quoting that, i would get old chasing [/quote] around! :)
-Torch on LED stays off, no relay switching. Forgot to look at the DRO...
-No it does not.
-I have set "onboard" to show when typing, but it does not show in this case. Showing it's keyboard is OK with me.
-No worries, i can live with it for now, that is the least of my problems with it.
-did not check, will do next time for sure, and run it from terminal.
Also, soft keyboard does not stick while run from here does. Have to check this on other PC's as well.
4 years 5 months ago #244091 by rodw
Replied by rodw on topic QtPlasmaC release.
If you are using bookworm to stay current with QTPlasmac, you need to build from source.
Debian only has a snapshot and is building its own debs, does not get a feed from the linuxcnc buildbot.
4 years 5 months ago #244262 by phillc54
I may have misunderstood your first post.
If you have "Soft Keybord" selected in the PARAMETERS tab then when you tap the entry box in the MDI panel the soft keyboard should appear. Is that not happening?
Having said that, I don't think the current soft keyboard is much good for MDI, I think I should change it so that the Onboard keyboard appears for MDI.
