QtPlasmaC release.
4 years 2 months ago #249669 by Samas322
Replied by Samas322 on topic QtPlasmaC release.
package install.. what is the difference of this?
4 years 2 months ago #249670 by Samas322
also if im looking at the last file specified in the error message: _init_.py
it is all empty..
4 years 2 months ago #249671 by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
Not sure as far as why one works and one doesn’t currently, but they were doing work on the package install stuff so something may have broken it.
I run a run in place version, was also going to explain how to downgrade if you were on run in place.
I’m not home so I can’t do any investigation right now.
You can downgrade by downloading one of the earlier packages from the buildbot site and installing it manually. You’ll have to search for examples on here of how to accomplish that.
4 years 2 months ago #249673 by snowgoer540
You could try reinstalling it in the package manager. (Backup your config folder someplace like your desktop just in case). Mark for complete removal, then install.
Come to think of it, I think there’s a way to downgrade from there too.
4 years 2 months ago #249675 by Samas322
ok i was doing some test and noticed that it was only the 16:9 version of qtplasmac that doesn't work. i switched to 4:3 and it is working now. i already tried to do a complete removal and reinstall but it doesnt worked. anyway im now able to continue my work so its ok for now and i will wait for a new update. And after this i will no longer update it as long as a stable version of qtplasmac will be released. thanks snowgoer540 for this quick response time! have a great day!
4 years 2 months ago #249676 by snowgoer540
Glad to hear it.
When I get home I’ll do a package install and see if I encounter the same.
Usually things are pretty stable, but it is part of being on the master branch sometimes…
That said, if I have work to do I generally update afterward, unless I want to take advantage of some specific new feature.
The following user(s) said Thank You: Samas322
Time to create page: 0.120 seconds
