Yep, I see that behavior too (nothing to do with your Debian release).
[/quote]Agreed but if afix is pushed to master branch, Tommy will need to build the source to get it!
Latest QtPlasmaC on Debian "Unstable", here is a strange one:
-home all
-wizard, 50x25mm box, inside leadin 4mm, 5mm radii on all corners
-wizard multiply at 5 columns 2 rows with 55 and 30 offsets
-send
-run
-stop using esc or cancel
-run again = it moves the start point to the second box
-stop again
-run again = it moves to start point to the third box
-rinse and repeat
-if left to continue, it will do all boxes, but they will not be where they should.
Something that does not need testing, why QtPlasmaC does not use the "machine-is-enabled" pin?
This is a PncConf generated config, not edited, it would not turn on the drives, while in Axis it does.
X-enable works.
