QtPlasmaC release.
2 years 8 months ago #293558 by tommylight
Replied by tommylight on topic QtPlasmaC release.
Noticed a strange issue today, using Debian 12.2 with 2.9.no idea as i am not in the shop now (1AM here), not updated for at least 4 months, so i will try to explain steps to reproduce it:
-the usual, start, home, move to some place on the table
-press F9 - all good
-ONLY if the torch does not reach the material, like between slats, it retracts and sends the error - all good
-now nothing works, no jogging, no F9, no motion, Start button flashes
-pressing ESC several times gets out of this condition, mostly, twice it did not had to disable/enable to get out
Anyone else can reproduce this on the latest version?
2 years 8 months ago #293736 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
I have not been able to emulate that issue but I did see that if a manual cut did not detect the material and then the cut was aborted, you could not start a new manual cut. I have a fix in the works for this.
2 years 8 months ago #293798 by Franklin
Replied by Franklin on topic QtPlasmaC release.
Hello, I noticed one bug in the cutting recovery mode, when I moved the torch using the arrows and pressed CANCEL MOVE, and then pressed the button to CYCLE RESUME, the program continues to move without probing.
2 years 8 months ago #293799 by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
Could you tell us what version you are on? It’s in the window’s title bar.
2 years 8 months ago #293802 by Franklin
I am using v2.10- 003.023
This bug was also on previous versions, I follow updates and try to always update my machines.
2 years 8 months ago #293804 by snowgoer540
No worries, since v2.9 and v2.10 have diverged significantly, it's best not to assume anything on our end :)
I do see the bug here. Phill or I will work up a fix and push it ASAP.
Thank you for the report!
Time to create page: 0.155 seconds
