Torch On HAL Pin when using 7i76e
5 years 6 months ago #206644 by txtrone
phillc54 wrote:
txtrone wrote: This is what I have, anything look out of whack?
Where might I find the pmx_test script?
There is a hint in the user guide.
linuxcnc.org/docs/2.8/html/plasma/plasma...-guide.html#pm_comms
I ran the pmx_test script. Found the port, S1 in my case, I can change the drop down box on the test screen and verify it is changing modes on my plasma unit (Normal, CPA, Gouge) ... I changed the ini file to /dev/ttyS1 ... got the following errors.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
Machine configuration directory is '/home/newpc/linuxcnc/configs/mark_i'
Machine configuration file is 'mark_i.ini'
INIFILE=/home/newpc/linuxcnc/configs/mark_i/mark_i.ini
VERSION=1.1
PARAMETER_FILE=imperial_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XXYZ
KINEMATICS=trivkins coordinates=XXYZ kinstype=BOTH
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./mark_i.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./mark_i_connections.hal
twopass:pass0: loadusr -Wn pmx485 pmx485 /dev/ttyS1
Could not open /dev/ttyS1 for Powermax communications
twopass: Error in file ././plasmac/plasmac.tcl:
pmx485 exited without becoming ready
Debug file information:
27117
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
5 years 6 months ago #206645 by txtrone
snowgoer540 wrote:
tommylight wrote: Ohmic Probe Enable must be an output, not input.
True, but it looks like he's attempting "hypersensing", so he will need one of the ohmic components. There's a few threads around here that explain it better than I can off the top of my head.
Would it be more straightforward to do away with "hypersensing" and use the relay method? I don't care either way... just want to get it running. thx
5 years 6 months ago #206646 by txtrone
What does Type and Dir mean on HAL Show in my attached screen cap?
5 years 6 months ago #206657 by tommylight
Type is the type of pin, be it bit, float, s32 etc.
Dir should be the direction of the signal looking from the LinuxCNC point of view. Might wana check this as i am a bit cloudy...
As for coms, might need to add the user to dialout, here is one of the many topics about that:
arduino.stackexchange.com/questions/7471...d-to-group-dialout-o
The following user(s) said Thank You: txtrone
5 years 6 months ago #206662 by txtrone
tommylight wrote: Type is the type of pin, be it bit, float, s32 etc.
Does that mean the aforementioned 'encoder input-b' is actually a 'bit out' or am I misunderstanding?
5 years 6 months ago #206665 by tommylight
It is for LinuxCNC, but not for us and not for the encoder, it is an input.
Time to create page: 0.162 seconds
