- Thank you received: 907
txtrone wrote:
snowgoer540 wrote:
snowgoer540 wrote: True, but it looks like he's attempting "hypersensing", so he will need one of the ohmic components. There's a few threads around here that explain it better than I can off the top of my head.
As I said, you need to use the ohmic.comp (included with LinuxCNC). Or ohmic2.comp, or ohmic3.comp (in the link below, as well as how to install them).
Rod has posted examples of how to hook up the hal stuff. Including his own .hal files.
Here's at least one thread to read: forum.linuxcnc.org/plasmac/38848-hypersensing-questions?start=0
It details my (and a few others by the end) journey into "hypersensing", and as such has a lot of answers to questions with regard to getting it working, how it's evolved, and why it is the way it is.
It's 28 pages long, but it's worth the read.
In a nutshell, you need to pass the ohmic probe output from PlasmaC to the ohmic component. In addition, you need to pass the encoder velocity to the ohmic component. The output of the ohmic component will be passed to the PlasmaC ohmic input.
Just sorted through the 28 pages. I am a bit confused on ohmic comp versions and if I have one installed already or not. How can I check to see if ohmic comp is installed already?
Also, what is the verdict on using a relay to interrupt the power supply?
snowgoer540 wrote: You have ohmic.comp installed by default. you would have to install ohmic3 (I wouldnt see much point in using ohmic2)User's choice.
snowgoer540 wrote: I suspect it's going to take issue with your ohmic enable HAL pin next as you are feeding a bit output to an encoder.
Correct, but not advisable since the pilot arc generates anything in the 2000V to 15000V and that should give it some distance in case something goes south.txtrone wrote: Wait a minute, what if I am not using the "Optional" relay?? Would I comment out the ohmic enable HAL pin?
tommylight wrote: Correct, but not advisable since the pilot arc generates anything in the 2000V to 15000V and that should give it some distance in case something goes south. But i think someone here made due without it.
