Torch On HAL Pin when using 7i76e
5 years 6 months ago #206567 by tommylight
The following user(s) said Thank You: txtrone
5 years 6 months ago #206569 by snowgoer540
tommylight wrote: Ohmic Probe Enable must be an output, not input.
True, but it looks like he's attempting "hypersensing", so he will need one of the ohmic components. There's a few threads around here that explain it better than I can off the top of my head.
5 years 6 months ago #206574 by rodw
The ohmic pins do not seem right regardless of the ohmic method. But Thats not the error here as Snowgoer pointed out.
Perhaps disable the RS485 comms for now and sort out the rest of the config. Mainly ohmic sensing.
5 years 6 months ago #206577 by txtrone
rodw wrote: The ohmic pins do not seem right regardless of the ohmic method. But Thats not the error here as Snowgoer pointed out.
Ok. Can I comment out the RS485 in the 'new' main ini file?
Any pointers on the ohmic pins?
5 years 6 months ago #206585 by txtrone
snowgoer540 wrote: You can use the pmx_test.py script to help you identify the correct port. Its usage is covered in the user guide.
I suspect it's going to take issue with your ohmic enable HAL pin next as you are feeding a bit output to an encoder.
Where might I find the pmx_test script?
Any suggestions regarding the HAL pin(s) I should be using?
5 years 6 months ago #206610 by phillc54
txtrone wrote: This is what I have, anything look out of whack?
There is a hint in the user guide.
linuxcnc.org/docs/2.8/html/plasma/plasma...-guide.html#pm_comms
The following user(s) said Thank You: snowgoer540, txtrone
Time to create page: 0.145 seconds
