setup qtplasmac
5 years 3 months ago #215120 by phillc54
Replied by phillc54 on topic setup qtplasmac
Great work. If you want to submit a PR to include the work I would be happy to merge it.
If you want to do a PR you would just need to make some minor changes to keep the code consistent with the existing. Also it would be better to rework the exising height_ovr_pressed function so both the GUI buttons and the external Hal pins use the same function rather than having two functions doing the same job.
5 years 3 months ago #215295 by fupeama
Replied by fupeama on topic setup qtplasmac
Ok, I tried to make PR. I did it for the first time, so maybe it works.
Martin
5 years 3 months ago #215297 by phillc54
Martin
I saw the PR, it looks good, I will test and merge tomorrow.
It would have been nice if you had renamed the pins so they were similar to the existing external pins, something like:
self.extHeightOvrMinusPin
Do you want to add them to the doc or do you want me to.
5 years 3 months ago #215307 by fupeama
OK I will rename pin.
something like this?
self.extHeightOvrPlusPin = self.h.newpin('ext_height_ovr_plus', hal.HAL_BIT, hal.HAL_IN)I would prefer you to add the information to the documentation because English is not my native language.
Martin
5 years 3 months ago #215309 by phillc54
Great, thanks for doing this. I'll do the docs tomorrow as well.
5 years 3 months ago #215497 by fupeama
Thanks for adding code to repo.
If you want, I can try write code for encoder height override too.
Martin
Time to create page: 0.136 seconds
