setup qtplasmac
4 years 9 months ago #231240 by rodw
Replied by rodw on topic setup qtplasmac
Wait for Phil, but i think its because its loading Python2. Pretty sure QTP needs Python 3
MX Linux or Debian 11.
For Debian 11  www.qtpyvcp.com/install/bullseye.html
For MX Linux, Snowy has a tutorial on the forum here.
The following user(s) said Thank You: billykid
4 years 9 months ago #231241 by billykid
Replied by billykid on topic setup qtplasmac
thanks Rod, in fact I have a hardisk with mx and it has all the pins I need. however he has wifi locked and i can't unlock it ... he tells me unlocked but in reality it is always locked. i have too many problems with the network in my nuc i3. with both mx and debian systems I have to turn off the power to the 7i80 board and turn it back on to make it work, long ago it went correctly without having to turn off anything.
4 years 9 months ago #231243 by rodw
Wifi's a bit funny to get going. I had 2 wifi dongles here and eventually I got one going but signal was too weak. Then pulled out the other one and found a repo on git hub. Once you can identify your chipset, google is your friend.
Same with your NIC too.
4 years 9 months ago #231247 by billykid
I confirm with mx19 the pins are all in place. except the wifi network  image missing /media/kunena/emoticons/sad.png   now I put a cable and a usb ethernet adapter then I'll see calmly.
4 years 9 months ago - 4 years 9 months ago #231479 by billykid
With the network cable, the internet and the 7i80 work together and the latency errors seem to have disappeared as well. often,
File Name: interfaces.txt
File Size:271 B
the mesa is not seen and I have to turn it off and on again to work, surely the interfaces file is done at random because before I had done it in a graphic way ... I am attaching it if someone (Rod) helps me to fix it image missing /media/kunena/emoticons/smile.png
Last edit: 4 years 9 months ago by billykid.
4 years 9 months ago #231500 by rodw
Is eth0 the name of the NIC? they are often different to that.
I think ip a (or ip -a) will tell you
Time to create page: 0.469 seconds
