setup qtplasmac
- fupeama
- Thank you received: 14
20 Oct 2021 12:47 #223662
by fupeama
Replied by fupeama on topic setup qtplasmac
Super,
Thanks Phill.
M
Thanks Phill.
M
- billykid
- Thank you received: 83
08 Jan 2022 20:13 #231161
by billykid
Replied by billykid on topic setup qtplasmac
hi, i put some external buttons run, pause / resume, stop, etc and they work but i don't see the pins qtplasmac.ext_thc_enable and qtplasmac.ext_torch_enable ... am i missing something?
- Thank you received: 4149
08 Jan 2022 21:15 - 08 Jan 2022 21:15 #231177
Replied by rodw on topic setup qtplasmac
you need to work in the postgui hal file because the pins are created in the gui
Last edit: 08 Jan 2022 21:15 by rodw.
- billykid
09 Jan 2022 09:21 #231224
by billykid
sure Rod! i put everything in postgui.hal, also the encoder for the height works, only the last 4 lines don't work and i had to comment them. if i look in hal show there are many external pins but not all.
- phillc54
- Thank you received: 2100
09 Jan 2022 09:35 #231227
by phillc54
Replied by phillc54 on topic setup qtplasmac
What is your version of QtPlasmac?
Are you getting any error messages in a terminal when starting LinuxCNC?
- billykid
09 Jan 2022 09:56 #231228
by billykid
I just updated, I am attaching the file with the terminal messages.
09 Jan 2022 12:32 #231240
Wait for Phil, but i think its because its loading Python2. Pretty sure QTP needs Python 3
MX Linux or Debian 11.
For Debian 11 www.qtpyvcp.com/install/bullseye.html
For MX Linux, Snowy has a tutorial on the forum here.
The following user(s) said Thank You: billykid
- billykid
09 Jan 2022 12:43 #231241
by billykid
thanks Rod, in fact I have a hardisk with mx and it has all the pins I need. however he has wifi locked and i can't unlock it ... he tells me unlocked but in reality it is always locked. i have too many problems with the network in my nuc i3. with both mx and debian systems I have to turn off the power to the 7i80 board and turn it back on to make it work, long ago it went correctly without having to turn off anything.
09 Jan 2022 12:48 #231243
Wifi's a bit funny to get going. I had 2 wifi dongles here and eventually I got one going but signal was too weak. Then pulled out the other one and found a repo on git hub. Once you can identify your chipset, google is your friend.
Same with your NIC too.
- billykid
09 Jan 2022 14:08 #231247
by billykid
Time to create page: 0.469 seconds
